Change the activation temperature of the auxiliary heater in the MSG?
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Günther
Post22-03-2009, 4:24    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
Hey, everyone!
Is there any way to adjust the software in the MSG regarding the activation temperature for the auxiliary heater?
How can I modify a glow plug heater (specifically, a 3-pin glow plug type for a Volkswagen Golf IV with an ALH engine, part number 038-906-012-M)?
Currently, the switch-over threshold is set to less than or equal to +0.9°C intake air temperature (G72) for activation.
Is there perhaps a program available on the market that allows you to read, modify, and re-install MSG software?
Is this also possible via the K-line? (Possibly with the help of VCDS??)
Or another question: Do the "friendly" forces have a way to install updates into an MSG?
Die im Forum beschriebene Hardwarelösung setzt ja den Ausbau und das Öffnen des MSG´s voraus. IcI would like to, but...
avoid potential future moisture ingress into the housing or at the connectors (due to aged seals!).
It's risky because it's unfortunately located in the water tank.
Thank you very much!
Gedenk(e)feier(lich):
Leben auf der Kugel -> es geht immer im Kreis herum.
Egal wie schnell dein Feuerzeug auch sein mag - du bist nur öfter wieder am Ausgangspunkt zurück!
Translated on 15-07-2026, 16:48.
Post22-03-2009, 14:02    Subject: Re: Changing the activation temperature of the auxiliary heater in the MSG? Quote
Günther wrote:
Hey, Buddies!
Would this also be possible via the K-line? - (possibly with the help of VCDS?)
The required hardware and software are nothing more than a basic chip tuning setup, because the auxiliary heater characteristic curve is hidden in the engine software, just like the performance-determining data.
Or another question: Do the "friendly" people have a way to install updates into an MSG module?
In principle, yes, if the MSG module is flashable AND there is an official update from VAG.
However, within the scope of the updates, only "serious" problems with widespread occurrence were addressed. For a software modification of the auxiliary heater, you need to find a chip tuner who has exceptionally good knowledge of the software.
Or you could become a chip tuner yourself, but the path to that is arduous and expensive...
Translated on 15-07-2026, 16:51.
Günther
Post24-03-2009, 3:20    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
Hello Ulf,
Thanks again for your explanation.
By the way, I really don't intend to become a chip tuner.
My car's standard power is enough for me -> No need for a sporty version!
I only want to change one parameter because the machine (and its interior) ...
They should become pleasantly soft and cozy relatively quickly in cool weather.
Hey, by the way, do you happen to know how one could determine whether an MSG file is flashable?
See you later - talk to you soon!
Translated on 15-07-2026, 16:54.
Post24-03-2009, 6:50    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
"038906012M is flashable... unfortunately, Günther is currently the only one who has asked about this, so the profitability of such a research project would be highly questionable."
Since I suspect VAG would also like it to be comfortably warm, I fear that increasing the temperature might have some disadvantages, such as a reduced battery lifespan.
Translated on 15-07-2026, 16:55.
Post24-03-2009, 9:53    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
Rainer K. wrote:
Since VAG probably also likes it to be comfortably warm, I fear that an increase in temperature has disadvantages of some kind, e.g., a reduced battery lifespan.
I would exclude this with 95% certainty because the electric auxiliary heater is switched off as soon as the average alternator load reaches about 100%. That means, based on my current information, a serious discharge of the battery is not to be expected, rather possibly premature wear of the relay contacts, because this thing doesn't just activate ~20 times per year, but depending on the desired heating curve, it activates ~200 times...
Therefore, the profitability of such a research project would be very questionable.
I might be able to reduce your research effort somewhat, because I am at least familiar with the parallel function of the PTC heater in the Polo (instead of glow plugs)icon_wink.gif.
Translated on 15-07-2026, 16:57.
Günther
Post27-03-2009, 18:46    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
Rainer K. wrote:
... daß eine Erhöhung der Temperatur Nachteile irgendwelcher Art hat, z.B. eine verringerte Batterielebensdauer.
Hello Rainer K.,
danke für Deine Info bzgl. MSG flashback...
So, my starter battery (120A) doesn't exceed a load of 60-65%, since it doesn't have features like seat heating, etc. This is also the case during afterglow.
and simultaneously turn on the auxiliary heating system at level 1. Therefore, it likely has no impact on the battery, as Ulf also mentioned.
Do you have any experience with WinOLS, or which software would you recommend for finding the corresponding characteristic curve?
or use the relevant code section within the MSG?
Günther.
Translated on 15-07-2026, 16:59.
Wiesel
Post27-03-2009, 19:27    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
You are aware that WinOLS...
a) costs a few thousand euros and...
b) is it only sold to companies or businesses?
Rainer and I both own the program legally...
and will probably react in a similarly annoyed way if someone were to come up with that idea.
Here, people are asking for help with using a cracked version.
Best regards, Micha.
Translated on 15-07-2026, 17:00.
christians
Post28-03-2009, 16:16    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
Subject: What is this nonsense? Does the software manufacturer have too much money? Even if only a very small number of private individuals buy such expensive software, I don't understand it.
Gruß Christian
Translated on 15-07-2026, 17:01.
Post28-03-2009, 16:37    Subject: Change the activation temperature of the auxiliary heater in the MSG? Quote
Hey, you might find it useful to be in "D-Land" (Germany), as the right of withdrawal and potential support issues (YOUR SOFTWARE BROKE MY CAR! IT WAS SO EXPENSIVE AND I'M SO DISAPPOINTED!!!! I WILL SUE YOU!!!) could be relevant there.
It would be quite weak to buy software that costs more on its own than a heater with installation. And the person selling it hasn't even corrected the checksum, and doesn't have a tool to read or write the software in the engine control unit.
The cheapest solution for the person asking the question would be a time delay or a switch with a resistor in series with the sensor.
Therefore, I'm happy to sit down and find a solution for you at a rate of €100 per hour (net). If that doesn't work for you or seems too expensive, feel free to invest your own time and money in equipment.
Translated on 15-07-2026, 17:03.
No new posts Additional coolant heater for the TDI Technical Articles
No new posts Skoda Octavia 1U: Change dashboard illumination to white Troubleshooting & Guides
No new posts Auxiliary Heater for VW T5 On-Board Diagnostics (OBD)
No new posts Auxiliary Heater Control Unit Diesel Engine Technology
No new posts Additional Heater for Sharan On-Board Diagnostics (OBD)
No new posts Auxiliary Heater Settings: How to Adjust On-Board Diagnostics (OBD)
