Car Door Problems: Troubleshooting & Repair
Babapapa
Post09-04-2009, 20:12    Subject: Car Door Problems: Troubleshooting & Repair Quote
Okay, so I replaced both microswitches on the driver's and passenger's doors, as suggested.
Everything is now working correctly on the driver's side door (the door light is on, the warning sound is working, and the interior light also turns on).
I'm still having problems with the passenger-side door.
The door light on the passenger-side door still isn't working when I open it. ;(
2. If I unlock the doors and open the passenger door, the alarm system no longer activates after about 30 seconds (which it always did before the microswitch replacement). Now, after about 30 seconds, the car locks the doors again (is this normal). icon_sad.gif
The car doesn't lock when I do the same thing on the driver's door (basically, unlocking, opening, and waiting). It only locks when I leave the doors closed.
Please help if you can!
Greetings, Babapapa.
Translated on 23-09-2026, 8:20.
BM
Avatar-BM
Post09-04-2009, 22:26    Subject: Car Door Problems: Troubleshooting & Repair Quote
2. When I unlock the doors and open the passenger door, the alarm system no longer activates after about 30 seconds (which it always did before the microswitch replacement). Now, after about 30 seconds, the car locks the doors again (is this normal). icon_sad.gif
Yes, that's normal because the control unit doesn't recognize that the door is open. For the same reason, the door light also doesn't work. So, check why the microswitch, or its ground circuit, isn't working (the door light is also controlled via ground). Have you resoldered the cold solder joints on the circuit board, or checked the lock to see if it's functioning?
Look at this: https://community.dieselschrauber.org/en/viewtopic.php?p=127777&highlight=l%F6tstelle#127777
3B5 AJM
Translated on 23-09-2026, 8:23.
KawaZ1000
Post14-04-2009, 15:41    Subject: Car Door Problems: Troubleshooting & Repair Quote
Take a look at the right-hand door wiring harness behind the trim panel. There might be a diode installed there that occasionally fails. While you're at it, check the wiring harness between the door and the body for any broken wires.
Merkel muss weg,schnell!!!
Translated on 23-09-2026, 8:24.
Babapapa
Post14-04-2009, 17:40    Subject: Car Door Problems: Troubleshooting & Repair Quote
What type of diode is installed (model or designation)?
I'm asking because I want to know if it's broken and if I can possibly get a replacement from Conrad.
KawaZ1000
Post14-04-2009, 19:38    Subject: Car Door Problems: Troubleshooting & Repair Quote
I can't tell you the exact part number, but it's available as an original replacement part from Volkswagen.
Translated on 23-09-2026, 8:25.
Babapapa
Post16-04-2009, 18:54    Subject: Problem Solved! Quick Fix & Solution. Quote
Hello everyone, I solved the problem by disassembling the lock again and rotating the microswitch 180 degrees before reassembling it (which makes sense since the lock is assembled in a mirrored configuration).
So, to everyone who still has this task ahead of them.
Mount the switch from Conrad (MBF5A) on the driver's side with the white marking facing DOWN, and on the passenger side with the marking facing UP.
In addition to the super glue, the switch can also be secured with a screw.
Have fun and good luck with the installation.
Best regards.
René.
Translated on 23-09-2026, 8:26.
No new posts Transporter 7D: Brake Pad Wear Light Always On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. 1Z Issues: Troubleshooting and Solutions Diesel Engine Technology
No new posts G4 Performance Issues: AGR Problems Persist. On-Board Diagnostics (OBD)
No new posts Cruise Control Not Working? Troubleshooting Guide. Diesel Engine Technology
No new posts HFLM 5: Still the same struggle? Diesel Engine Technology
