mathiasr81
19-06-2009, 23:29 Subject: A6 C4 TDI Engine Control Unit |
Hello.
I have a question.
When replacing the engine control unit (ECU) on a Volkswagen A6 C4 2.5 TDI with the AEL engine, are there any issues with the immobilizer system, or is there a separate control unit for that?
Translated on 26-08-2026, 20:33.
wolle Blaumann
22-06-2009, 11:26 Subject: A6 C4 TDI Engine Control Unit |
There are generally no problems.
The WFS is included in the MSG. You need to set the corresponding value in the MSG to 0 using VAG-COM and then start the engine.
Please don't be upset if I don't describe the adaptation in more detail. I'm not sure if that's something that's well-received here, and I don't want to overstep any boundaries.
But you should be able to find out by searching.
Otherwise, someone from the decision-making team here could just send me a quick "OK" via private message. Then I'll email you and explain how it works.
Wool. 2018er A6 Avant Allroad, 3.0 Bi-TDI mit prima Ausstattung
Translated on 26-08-2026, 20:34.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
Profile PM WWW Garage |
mathiasr81
22-06-2009, 17:34 Subject: A6 C4 TDI Engine Control Unit |
Thank you for the quick responses. But I have one more question. Does the control unit need to be installed beforehand, or can I take the control unit to the Audi dealership and then simply replace the old one in the car afterwards?
Translated on 26-08-2026, 20:35.
22-06-2009, 17:55 Subject: A6 C4 TDI Engine Control Unit |
Built-in.
Translated on 26-08-2026, 20:36.
