Question about Maik's VAGCOM interface
andi
Post25-04-2003, 15:55    Subject: Question about Maik's VAGCOM interface Quote
Hello diesel mechanics,
'I recreated Maik's OBD interface some time ago, and I have a question: What is the exact purpose of the 10k and 100k potentiometers (trimmers)?' While the thing is now working after a long period of calibration, I would still have been interested in understanding its true purpose and ideal settings.
And: Which of V1 and V3 shows TxD, and which shows RxD?
My experiences/tips regarding this matter:
-In my Golf, manufactured in 2000, the mass is only connected to ODB pin 5. Pin 4 is not connected (there is no contact insert). In the Audi A4, it ranks 4th.
- Occasionally, I receive 'Too many communication errors' messages. Alignment issue?
- To reduce noise (e.g., from the vehicle's power supply), you can connect a 100nF ceramic capacitor and a 10-100µF electrolytic capacitor between the in-GND and out-GND terminals of the voltage regulator. Use the larger electrolytic capacitor on the input side. It also works without it.
- Traffic LEDs can be added for the serial side (mainly useful for debugging on the adapter PC). Connect LEDs with a 470 Ohm resistor from serial pin 2 to pin 5, and from pin 3 to pin 5. The cathode of each LED should be connected to pin 5. To indicate a low level, simply reverse the polarity of the LEDs (low = -12V).
- Very thin, flat connectors are suitable for the ODB socket. Can you also adjust or refine something by filing?
'Are there any really cheap sources for ODB connectors? I haven't found anything below 12 euros, and that's too expensive for me.'
Have a nice weekend.
andi
Post25-04-2003, 16:20    Subject: Re: Question about Maik's VAGCOM interface Quote
andi wrote:
I recreated Maik's OBD interface some time ago, and I have a question: What is the exact purpose of the 10k and 100k potentiometers (trimmers)? The thing works now, after a long period of calibration, but I would still have been interested in the real meaning and the ideal settings.
Hi Andi,
She took that from my earlier (unrefined) opto proposals, as far as I know.
This allows you to adjust the H-L detection threshold of the adapter for the K-line, as well as the K-pullup (which is roughly the impedance of the K-line).
andi
Post25-04-2003, 17:23    Subject: Question about Maik's VAGCOM interface Quote
and which of the two is for what purpose? do the designations 1 and 2 correspond to each other?
Post25-04-2003, 19:21    Subject: Question about Maik's VAGCOM interface Quote
andi wrote:
and which of the two is for what? do the designations 1 and 2 match?
Hi.
The trimmer, which is located between K-Line and icon_smile_thumb_up.gif2 volts, controls the K-impedance.
The other one is for the detection threshold.
Maik
Post28-04-2003, 7:36    Subject: Re: Question about Maik's VAGCOM interface Quote
Some time ago, I replicated Maik's OBD interface. First, a question: What is the exact purpose of the 10k and 100k trimmer potentiometers? The thing works now, after a long period of calibration, but I would still have been interested in the real meaning and the ideal settings.
Hi Andi,
This allows you to modify the H-L detection threshold of the adapter for the K-line, as well as the K-pullup (which is roughly the impedance of the K-line).
That's exactly right. When I have a little more time again, I will revise the circuit and also develop a new PCB icon_smile.gif.
Maik.
No new posts Frage zu Maiks VAGCOM Adapter Diesel Engine Technology
No new posts Question about VAGCOM On-Board Diagnostics (OBD)
No new posts Help, I can't get my Maix adapter to work Diesel Engine Technology
No new posts probleme mit diagnose interface beim polo 3 g40 Diesel Engine Technology
