3C: AHK Retrofit, Bus Idle Issues
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Post23-06-2009, 14:46    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
I retrofitted a tow hitch to my Passat 3C and installed an aftermarket wiring kit. Sure, here is the translation of the text from German to English:
"This should be from Bosal."
Now I have several errors stored in the error memory.
Okay, bitte gib mir den deutschen Text, den du ĂŒbersetzt haben möchtest.
***EDIT: I'm going to cut this short here: I initially thought there might be a software update from VW for this, but that doesn't apply to my vehicle. Thank you to vagtuning.
"Does anyone know of similar issues with other vehicles, or perhaps even a solution to this problem?" I'm concerned that constant communication problems might prevent the CAN bus from settling down, which could lead to the battery being drained.
"Error code log attached (VIN removed to avoid directly criticizing the dealer). Communication problems occur every time a key is removed from the ignition. The trailer hitch lighting functions perfectly, both with and without the ignition on." AHK-related errors occur in the body control module (BCM), comfort control module (CCM), gateway control module (GCM), and AHK control module.
Guste.
Code:
Donnerstag,04,Juni,2009,17:16:58:49705
VCDS Version: RKS 805.2
Datenstand: 20090313
Fahrzeugtyp: 3C0
Scan: 01 02 03 04 08 09 15 16 17 18 19 25 37 42 44 46 47 52 53 55
          56 62 69 72 77
Fahrzeug-Ident.-Nr.: WVWZZZ3CZ8E006xxx
01-Motor -- Status: OK 0000
02-Getriebe -- Status: OK 0000
03-Bremsen -- Status: OK 0000
04-Lenkwinkelsensor -- Status: OK 0000
08-Klima/Heizung -- Status: OK 0000
09-Bordnetz -- Status: Fehler 0010
15-Airbag -- Status: OK 0000
16-Lenkrad -- Status: OK 0000
17-Kombiinstrument -- Status: OK 0000
18-Standheizung -- Status: Fehler 0010
19-CAN-Gateway -- Status: Fehler 0010
25-Wegfahrsperre -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-TĂŒrelektr. Fahrer -- Status: OK 0000
44-Lenkhilfe -- Status: OK 0000
46-Komfortsystem -- Status: Fehler 0010
47-Soundsystem -- Status: OK 0000
52-TĂŒrelektr. Beifahr. -- Status: OK 0000
53-Feststellbremse -- Status: OK 0000
55-Leuchtweitenreg. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-TĂŒrelektr. hi. li. -- Status: Sporadischer Kommunikationsfehler 1000
69-AnhÀnger -- Status: Sporadischer Kommunikationsfehler 1000
72-TĂŒrelektr. hi. re. -- Status: OK 0000
77-Telefon -- Status: OK 0000
Adresse 01: Motor        Labeldatei: RKS\03G-906-021-BMM.lbl
   Teilenummer SW: 03G 906 021 NK    HW: 03G 906 021 AB
   Bauteil: R4 2,0L EDC G000AG  9971
   Revision: --H07---    Seriennummer: VWZCZ000000000
   Codierung: 0000078
   Betriebsnr.: WSC 48992 143 80611
Kein(e) Fehler gefunden.
Readiness: 0 0 0 0 0
Adresse 02: Getriebe        Labeldatei: RKS\02E-300-0xx.lbl
   Teilenummer SW: 02E 300 051     HW: 02E 927 770 AJ
   Bauteil: GSG DSG AG6     431 1817
   Revision: 04843012    Seriennummer: 00000809080793
   Codierung: 0000020
   Betriebsnr.: WSC 04926 001 00001
Adresse 03: Bremsen        Labeldatei: Keine
   Teilenummer SW: 3C0 614 109 D    HW: 3C0 614 109 D
   Bauteil: J104    C4 440 V2   0003
   Revision: --020---    Seriennummer: 00000775427338
   Codierung: 0000270
   Betriebsnr.: WSC 05311 000 00000
Adresse 08: Klima/Heizung        Labeldatei: RKS\3C0-907-044.lbl
   Teilenummer SW: 3C0 907 044 CD    HW: 3C0 907 044 CD
   Bauteil: ClimatronicPQ46 122 0708
   Revision: 00122021    Seriennummer: 00000000000000
Adresse 09: Bordnetz        Labeldatei: RKS\3C0-937-049-30-H.lbl
   Teilenummer SW: 3C0 937 049 AL    HW: 3C0 937 049 AL
   Bauteil: Bordnetz-SG     H54 2202
   Revision: 00H54000    Seriennummer: 01000007013612
   Codierung: E38A8F6701281A00470A00000F000000000F5D435C400100000000000000
   Betriebsnr.: WSC 05124 000 00000
   Teilenummer: 3C1 955 419 A
   Bauteil: Wischer 020507 003  0205
   Codierung: 00046997
   Teilenummer: 1K0 955 559 AB
   Bauteil: RLS     210507 020  0105
   Codierung: 00479269
2 Fehler gefunden:
01333 - TĂŒrsteuergerĂ€t hinten links (J388)
            004 - kein Signal/Kommunikation - Sporadisch
             Umgebungsbedingungen:
                    Fehlerstatus: 00100100
                    FehlerprioritĂ€t: 2
                    FehlerhĂ€ufigkeit: 1
                    VerlernzĂ€hler: 19
                    Kilometerstand: 111832 km
                    Zeitangabe: 0
                    Datum: 2009.05.14
                    Zeit: 17:27:00
                        aus
                    Spannung: 12.40 V
                        aus
                        ein
                        aus
                        aus
                        aus
01517 - SteuergerĂ€t fĂŒr AnhĂ€ngererkennung (J345)
                    FehlerprioritĂ€t: 2
                    FehlerhĂ€ufigkeit: 254
                    VerlernzĂ€hler: 40
                    Kilometerstand: 111024 km
                    Zeitangabe: 0
                    Datum: 2009.04.20
                    Zeit: 14:05:00
                        aus
                    Spannung: 12.35 V
                        aus
                        ein
                        aus
                        aus
                        aus
Adresse 15: Airbag        Labeldatei: RKS\3C0-909-605.lbl
   Teilenummer SW: 3C0 909 605 N    HW: 3C0 909 605 N
   Bauteil: 19 AIRBAG VW8R  032 2522
   Revision: 13032000    Seriennummer: 003B2P9SJP3$
   Codierung: 0012601
Adresse 16: Lenkrad        Labeldatei: RKS\3C0-953-549.lbl
   Teilenummer SW: 3C0 953 549 K    HW: 3C0 953 549 K
   Bauteil: J0527               0015
   Revision: 00006000    Seriennummer: 3C9953507BG
   Codierung: 0001112
   Teilenummer: XXXXXXXXXXX
   Bauteil: E0221           002 0010
Adresse 17: Kombiinstrument        Labeldatei: RKS\3C0-920-xxx-17.lbl
   Teilenummer SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Bauteil: KOMBIINSTRUMENT VD1 1216
   Revision: V0002000    Seriennummer: 00000000000000
   Codierung: 0007105
   Betriebsnr.: WSC 48992 141 87099
Adresse 18: Standheizung        Labeldatei: RKS\1K0-815-007.lbl
   Teilenummer: 1K0 815 007 BH
   Bauteil: Standheizer     042 4404
   Revision: 00042000    Seriennummer: 09011075000000
   Codierung: 0000012
1 Fehler gefunden:
01407 - Flammenabbruch
            000 -  -  - Sporadisch
                    Fehlerstatus: 00100000
                    FehlerprioritĂ€t: 3
                    VerlernzĂ€hler: 29
                    Kilometerstand: 112028 km
                    Zeitangabe: 0
                    Datum: 2009.05.25
                    Zeit: 07:13:12
                        Start
                    Temperatur: 80.0°C
                    Temperatur: 78.0°C
                    Spannung: 14.45 V
Adresse 19: CAN-Gateway        Labeldatei: 3C0-907-530.lbl
   Teilenummer SW: 3C0 907 530 E    HW: 3C0 907 951
   Bauteil: J533__Gateway   H10 0080
   Revision:   H10       Seriennummer: 1200P0752206E2
   Codierung: FD817F46500E022002
2 Fehler gefunden:
                    FehlerprioritĂ€t: 2
                    FehlerhĂ€ufigkeit: 216
                    VerlernzĂ€hler: 40
                    Zeitangabe: 0
                    Datum: 2009.04.20
                    Zeit: 14:05:22
                    FehlerprioritĂ€t: 2
                    VerlernzĂ€hler: 18
                    Zeitangabe: 0
                    Datum: 2009.05.14
                    Zeit: 17:27:29
Adresse 25: Wegfahrsperre        Labeldatei: RKS\3C0-959-433-25.lbl
   Teilenummer SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Bauteil:    IMMO         042 0383
   Revision: 00042000    Seriennummer: VWZCZ000000000
   Betriebsnr.: WSC 131071 1023 2097151
   Teilenummer: 3C0 905 861 G
   Bauteil:    ELV          027 0380
   3C0905861G     ELV          027 0380
Adresse 37: Navigation        Labeldatei: RKS\1K0-919-887-MFD2.lbl
   Teilenummer: 1K0 919 887 F
   Bauteil:      Navigation     0030
   Codierung: 0000101
   Betriebsnr.: WSC 05314 000 00000
Adresse 42: TĂŒrelektr. Fahrer        Labeldatei: RKS\1K0-959-701-MIN3.lbl
   Teilenummer SW: 1K0 959 701 P    HW: 1K0 959 793 L
   Bauteil: J386  TUER-SG FT    1131
   Revision: 32008001    Seriennummer: 00000025278510
   Codierung: 0000181
Adresse 44: Lenkhilfe        Labeldatei: RKS\1Kx-909-14x.lbl
   Teilenummer: 1K1 909 144 M
   Bauteil: EPS_ZFLS Kl.135 H08 1901
   Betriebsnr.: WSC 02069 000 90108
Adresse 46: Komfortsystem        Labeldatei: RKS\3C0-959-433-46.clb
   Bauteil:    KSG PQ46 ELV 042 0472
   Codierung: 0091020051034E7630001415700C4F0E507840
   Teilenummer: 1K0 951 605 C
   Bauteil: LIN BACKUP HORN H03 1301
   Bauteil:       NGS n.mounted
   Bauteil:      IRUE n.mounted
1 Fehler gefunden:
                    FehlerprioritĂ€t: 4
                    VerlernzĂ€hler: 40
                    Zeitangabe: 0
                    Datum: 2009.04.20
                    Zeit: 14:05:20
Adresse 47: Soundsystem        Labeldatei: RKS\3C0-035-456.lbl
   Teilenummer: 3C0 035 456 D
   Bauteil: 08K Audioverst.     0005
   Revision: 00002000    Seriennummer: 00000004106284
Adresse 52: TĂŒrelektr. Beifahr.        Labeldatei: RKS\1K0-959-702-MIN3.lbl
   Teilenummer SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Bauteil: J387  TUER-SG BT    1131
   Revision: 32008001    Seriennummer: 00000075278503
   Codierung: 0000180
Adresse 53: Feststellbremse
nicht erreichbar
Adresse 55: Leuchtweitenreg.        Labeldatei: RKS\5M0-907-357-A.lbl
   Teilenummer SW: 5M0 907 357 A    HW: 5M0 907 357 A
   Bauteil: AFS-Steuergeraet    X014
   Revision:   H01       Seriennummer:
   Codierung: 2301953
   Teilenummer: 7L6 941 329
   Bauteil: AFS-Lst.-Modul l    X018
   Codierung: 00000035
   Teilenummer: 7L6 941 330
   Bauteil: AFS-Lst.-Modul r    X018
   Codierung: 00000035
Adresse 56: Radio        Labeldatei: RKS\1K0-035-095.lbl
   Teilenummer: 1K0 035 095 G
   Bauteil:        Radio        0030
   Codierung: 0012042
Adresse 62: TĂŒrelektr. hi. li.        Labeldatei: RKS\1K0-959-703-GEN3.lbl
   Teilenummer SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Bauteil: J388   TUER-SG HL   1119
   Revision: 11006001    Seriennummer: 00000001728990
   Codierung: 0000144
Adresse 69: AnhĂ€nger        Labeldatei: Keine
   Teilenummer SW: 30/ 1V2 .0    HW: 30/ 1V2 .0
   Bauteil: ANHAENGER_MODULE UN 0030
   Codierung: 0000001
5 Fehler gefunden:
02562 - Lampen fĂŒr Bremslicht am AnhĂ€nger
            011 - Unterbrechung
02563 - Lampe fĂŒr Schlusslicht rechts am AnhĂ€nger (M61)
            011 - Unterbrechung
02564 - Lampe fĂŒr Schlusslicht links am AnhĂ€nger (M60)
            011 - Unterbrechung
02565 - Blinkleuchten rechts am AnhÀnger (M63)
            011 - Unterbrechung
02566 - Blinkleuchten links am AnhÀnger (M62)
            011 - Unterbrechung
Adresse 72: TĂŒrelektr. hi. re.        Labeldatei: RKS\1K0-959-704-GEN3.lbl
   Teilenummer SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Bauteil: J389   TUER-SG HR   1119
   Revision: 11006001    Seriennummer: 00000001734546
   Codierung: 0000144
Adresse 77: Telefon        Labeldatei: RKS\3C0-035-729.lbl
   Teilenummer SW: 3C0 035 729 G    HW: 3C0 035 729 G
   Bauteil: Telefon             7609
   Revision: 00012000    Seriennummer: 0000000912806
   Codierung: 0016041
Ende   --------------------------------------------------------------------
Post23-06-2009, 17:21    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
It is incomprehensible to me why a mandatory AHK test is required for a software update of a gateway control unit (which was already installed in the car before the AHK was added).
Is there another TPL available for the gateway? Perhaps there will be an update available even for cars without a trailer hitch, in which case it would be difficult to perform an AHK function test, wouldn't it? icon_cool.gif
Once the latest software is installed, it doesn't matter to you whether the reason for the update was a bug in the AHK or something else.
vagtuning
Post24-06-2009, 16:28    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
Your GW cannot be updated further, as the TPI only supports vehicle-related data.
with a gateway up to a maximum of... Index C applies, but you have installed Index E!
Post24-06-2009, 23:28    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
vagtuning wrote:
Your GW cannot be further updated, as the TPI is only for vehicles.
with a gateway up to a maximum of... Index C applies - and you have installed Index E!
Oh my.
You're welcome!
Although I had paid very close attention to the index, I hadn't noticed the leading three digits, so "xxx 907 530 E" becomes "xxx 907 530 K". I hadn't noticed that the first list only included 1K0 control units, while the 3C0 control units are listed further down, and, as you correctly pointed out, only up to index C.
Therefore, the question of whether Volkswagen will release a GW update is no longer relevant.
There's only one thing left to consider: what else can I do?
I've recently learned from an acquaintance who installed a Westfalia electric drive kit on their Touran (manufactured in 2009), and it seems to be exhibiting the same error messages in the same control units. This is particularly surprising, considering that Westfalia is supposedly the company that manufactures the VW control units. Some forums even report that, underneath the Westfalia retrofit sticker, there was a VW sticker.
Guste.
Post25-06-2009, 7:44    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
Hi.
I'm having trouble with my...
Code:
   Teilenummer SW: 3C0 907 530 C    HW: 3C0 907 951 A
   Bauteil: Gateway         007 0040
   Revision: 00007000    Seriennummer: 0700C06C180274
   Codierung: 7DFD0C14C62002
Problems when I look at the org. AHK, are you listening?
Post25-06-2009, 9:30    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
Code:
3C0 907 530 C    0040
I'm dealing with my problems when I look at the org. AHK, are you ready?
dieselmartin wrote:
Yep, a dead battery due to a lack of bus tranquility. Drive to VW and have the software updated from version 40 to 48 according to the TPL (Technical Product Lifecycle) guidelines.
I'll send you an email with more details shortly.
Hendrik.
ruebasan
Post15-08-2009, 16:29    Subject: Re: 3C: Retrofitting AHK, Bus Ruhe Problems Quote
Hello guste100,
I'm having the same problem!
The trailer hitch with control unit and cut wiring harness.
I bought these parts from a car dismantler; they are supposed to be in a...
Passat 3C model. The tow hitch is made by Westfalia.
Here's a section of the log from my Passat:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 3C0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56 62 69 72
Vehicle Identification Number: WVWZZZ3CZ7Exxxxxx
00-Steering angle sensor -- Status: OK 0000
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
08-Climate/Heating Unit -- Status: OK 0000
09-Main Electrical System -- Status: Error 0010.
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnostic interface -- Status: Error 0010.
Immobilizer -- Status: OK 0000
42-door electric. Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: Error 0010.
52-door electric. Front passenger seat. -- Status: OK 0000.
53-Parking brake -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000.
69 followers -- Status: Intermittent communication error 1000.
72-Door, electric, high, right side -- Status: OK 0000.
"Der schnelle braune Fuchs springt ĂŒber den faulen Hund."
Address 09: Central Electronics
Label file: DRV\3C0-937-049-30-H.lbl
Part number SW: 3C8 937 049 E Hardware number: 3C8 937 049 E
Component: On-board network module H54 2602.
Revision: 00H54000 Serial Number: 00000005798099
Encoding: 008C8F0700041000400A00000F000000000959435C000000000000000000
Operating Number: WSC 00000 000 00000
Part number: 3C1 955 419 A
Part: Wiper 130307 003 0205
Encoding: 00046997
"1 error found:"
01517 - Trailer detection control unit (J345)
004 - No signal/communication - Sporadically.
Environmental conditions:
Error status: 00100100
Error priority: 6
Error frequency: 254
Lost Count: 130
Mileage: 15,090 km
Time: 0
text
from
Voltage: 11.75 V
text
from
one
text
from
text
from
text
from
Address 19: Diagnostic interface
Label file: 3C0-907-530.lbl
Part number SW: 3C0 907 530 C, HW: 3C0 907 951 A.
Component: Gateway 007 0040
Revision: 00007000 Serial number: 0700C07413036E
Encoding: 3DFD8C04C22002
Operating number: WSC 05311 000 00000
"1 error found:"
Error priority: 2
Error frequency: 150.
Lost Count: 130
Mileage: 15,090 km
Time: 0
Date: 2000.00.00
Time: 19:39:32
Address 46: Comfort System Label file: DRV\3C0-959-433-46.clb
Part number SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: KSG PQ46 ELV 042 0472
Revision: 00042000 Serial Number: VWZCZ000000000
Encoding: 0091020051030E763004941570084F0B607CA0
Component: Sounder, not mounted.
Component: NGS, not mounted.
Component: IRUE, not mounted.
"1 error found:"
Error priority: 4
Error frequency: 153.
Lost Count: 130
Mileage: 15,090 km
Time: 0
Date: 2000.00.00
Time: 19:39:29
Address 69: Trailer (J345) Label file: DRV\1K0-907-383-MY7.lbl
Part number SW: 1K0 907 383 B, Hardware number: 1K0 907 383 B.
Part: Trailer H13 0050
Revision: 2A000000 Serial number: 00005500000532
Encoding: 0100000200000000
Operating number: WSC 00028 028 00001
No error codes found.
Last month, the car was at VW for its inspection, but...
It also didn't make any difference.
I found a note in an installation manual for an Audi on the internet:
Regarding the "no signal/communication - sporadic" message.
read "you should simply ignore this notice."
I don't see that as a solution!
ruebasan
Post15-08-2009, 20:39    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
Hello Ruebesan,
At least you have an original VW trailer hitch control unit. Your gateway is also up to date.
This is a real problem that Volkswagen should really try to solve. Unfortunately, I suspect that VW will point out that the AHK control unit is not the latest version (the current version is index E, not B) and that they will try to replace the AHK control unit.
It would be interesting to know if it would be better then. But are you sure you want to take on those costs without any guarantee?
Short question: Have you checked if the DWA (door/window alarm) is working for you? I haven't noticed any malfunctions on my end. Recently, I wanted to test if the alarm system (as described in the manual) works when the DWA is connected. According to the manual, the alarm system should trigger if the DWA is activated and then the plug is pulled. Unfortunately, I haven't been able to achieve that yet, even though all the lights on the caravan are correctly wired and functioning.
Perhaps the DWA function is the one that doesn't work in the older STGs and some retrofitted AHK-STGs. It would be interesting to know if this feature was already available on the first 3C models from 2005, or if it was implemented later.
Guste.
vagtuning
Post15-08-2009, 20:51    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
I still have some Index D plus internal wiring harnesses available.
Only the wiring harness to the connector is missing.
 AHK
 File size:  710.48 KB
 Viewed:  12893 times
Post15-08-2009, 20:58    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
Do you happen to know if the errors listed above occurred with that?
What would you like in return?
vagtuning
Post15-08-2009, 21:03    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
I don't have precise answers to either the first or the second question.
Opinions or beliefs, but the latter doesn't really belong here either.
It was mainly intended to be informative; if you need anything, just reach out via private message.
Post15-08-2009, 23:02    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
My Index E surprisingly doesn't have any problems with the C CAN-GW using software 0040, even though there's a TPL associated with it.
Perhaps Guste can test drive the D sometime icon_smile.gif. Thanks to the second battery, you can quickly access the connectors, right?
Post16-08-2009, 7:44    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
dieselmartin wrote:
Maybe guste can test drive the D sometime icon_smile.gif. Thanks to the second battery, you can quickly access the connectors, right?
That's a great idea!
But (aside from the fact that I don't know if vagtuning would even lend out the control unit), my aftermarket Bosal E-kit unfortunately has completely different connectors (or only one instead of two), so while I can easily access it, I can't simply swap them around.
Otherwise, I probably would have jumped in without further questioning. icon_wink.gif
But I'm curious to see if Ruebesan wants to take the test, and if so, whether it could then be narrowed down to the AHK-STG group.
Guste.
ruebasan
Post16-08-2009, 12:44    Subject: 3C: AHK Retrofit, Bus Idle Issues Quote
I also hoped that during the inspection at VW, they would find a...
new software for the trailer hitch control unit.
Unfortunately, that didn't happen.
I would try swapping the test with the control unit.
already carry out...
ruebasan
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Problems: 1.4 16V Gasoline Engine Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts RCD510: Can You Trust This Bus Silence? Electrical Systems, Vehicle Electronics, Multimedia
No new posts DPF Retrofit for RME Vehicles Diesel Engine Technology
No new posts TDI Catalytic Converter Retrofit by VAG? Diesel Engine Technology
No new posts 1.6 TD Catalytic Converter Retrofit? Diesel Engine Technology
