Intercooler for 110kW TDI PD Engine
Raoul
Post02-05-2003, 12:10    Subject: Intercooler for 110kW TDI PD Engine Quote
Hello!
Could someone tell me if the intercooler for the 110kW TDI PD engine is larger than the one for the 96kW TDI PD engine? I've heard different things about it.
Thank you and best regards.
Raoul.
Translated on 15-09-2026, 16:29.
kenny
Post02-05-2003, 18:59    Subject: Intercooler for 110kW TDI PD Engine Quote
Try using the search function; something similar has been posted here before. It might be called LLK ALR or something like that; anyway, it's a huge file!
Raoul
Post02-05-2003, 21:42    Subject: Intercooler for 110kW TDI PD Engine Quote
Okay, the coolant level sensor for the 110kW model is larger.
Okay, here's the translation:
"Now, my second question. Can a 110kW liquid-cooled turbocharger (LLK) or another LLK (larger or with a better network) be installed in a 96kW TDI engine that has been chipped to 117kW? Shouldn't the cooling capacity be better suited to the power output of my engine?"
Raoul.
Translated on 15-09-2026, 16:30.
Post03-05-2003, 7:58    Subject: Intercooler for 110kW TDI PD Engine Quote
Try it again using the search function and enter "150 LLK". You'll notice that you won't get much of an improvement, and you might even experience worse performance and a significant dent in your wallet.
If you're already planning to get the one from the 110kW TDI engine, which is located in the center, transversely behind the radiator, then you might also look for one from a 220 CDI. They look almost identical and are often available.
It won't be cheap, though!
Translated on 15-09-2026, 16:31.
No new posts Oil pressure issues with TDI 110kW?? Diesel Engine Technology
No new posts T6 TDI Water Pump: Should You Replace It? Diesel Engine Technology
No new posts Intercooler for Audi TT/A8 TDI 150 Diesel Engine Technology
This topic is locked, you cannot edit or reply. Oil in the air cooler Diesel Engine Technology
