VW Passat 3B6 2.0 TDI (BGW) measurement blocks
ormowiec
Karma: +0 / -1   Thank you, like it!
Post09-09-2009, 13:15    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
"First, I apologize for writing in English - my knowledge of German is very poor (passing the anti-spam questions was really difficult icon_biggrin.gif)."
I am looking for standard values for engine measuring blocks. Engine code BGW, VW Passat Variant 2.0 TDI, 2004 with DPF. I suspect the PD injectors are failing (BIP values in the 023 range are up to 40).
ORMO
Translated on 14-07-2026, 23:57.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post09-09-2009, 19:25    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Standard values for the engine measurement module (MWB) 23 =
-100 to +100
Passat Variant BGW 2005
Translated on 14-07-2026, 23:58.
Post09-09-2009, 20:43    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Just check your VCDS label file...
ormowiec
Post10-09-2009, 8:37    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Hi.
Sure, you're welcome.
Just look in your VCDS label file...
I have VCDS versions 805.4-PL and 908-EN, and there is no label file available for this engine icon_sad.gif.
Standard values for engine control unit (ECU) data block MWB 23 =
-100 to +100
Well, in fact, I was looking for this block vals icon_smile.gif, thank you very much. Are you sure that the BIP (Bosch Injection Pump) has such a large range in this engine? As far as I know, for typical TDI-PD engines, it's usually around +/- 30.
[Edit Admin: I think there is absolutely no need to link to some file hosters as the attachment function in this forum is inteded for this purpose.Bitte gib mir den deutschen Text, den du übersetzt haben möchtest.
ORMO
Please provide the text you would like me to translate from German to English.
one more question.
004.4 = camshaft/crankshaft synchronization, similar to that found in the 1.9 TDI-PD engine?
Translated on 15-07-2026, 0:00.
Steffen W
Post10-09-2009, 20:16    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
The name of the label file is 038-906-016-BGW.lbl, and it's located in the "labels" directory.
Yes, and I'm certain, from +100 to -100.
Translated on 15-07-2026, 0:02.
ormowiec
Post11-09-2009, 7:46    Subject: VW Passat 3B6 2.0 TDI (BGW) measurement blocks Quote
Okay, I'm sure there isn't a file with that name in my VCDS labels. There's nothing listed with "*BGW*".
And yes,iam sure +100 to -100.
Thank you very much icon_biggrin.gif.
Translated on 15-07-2026, 0:03.
No new posts Passat B5: Intercooler Hose Special Offer - 74/96 kW Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts Passat combination instrument cluster 1998 to 04.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Log Passat v6 TDI Raw Upload
No new posts Passat 3BG MFL: Parts & Accessories Electrical Systems, Vehicle Electronics, Multimedia
No new posts Passat 3B: Catalytic Converter from 110 PS TDI to 115 PS ... Diesel Engine Technology
No new posts Passat PD ATJ: Engine Performance Issues Diesel Engine Technology
