I have a Passat B4 1.9 TDI, manufactured in 1996, that occasionally has an uneven idle speed / it occasionally jerks while idling.
The fuel injection pump was recently replaced.
I checked it, but unfortunately, no error codes were stored. In the MWB 10, the air mass seems much too high to me; even at full load, it only increases by about 80 mg/H. I unfortunately didn't record any data logs at full load or perform a test drive. Could the mass airflow sensor (MAF) be the cause?
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine Control (028 906 021 DD)
15:27:04 Block 004: Start of injection.
882 /min - Motor speed.
1.7 °v.OT Injection start (TARGET)
1.8 °v.OT Injection start (ACTUAL)
52.3% Key-to-injection ratio.
15:27:04 Block 005: Starting conditions.
26.6 mg/H - Initial injection amount.
1.8 °v.OT Injection start.
25.2°C Coolant temperature.
15:27:04 Block 010: Air quality parameters.
518.7 mg/H of air intake mass.
982.1 mbar atmospheric pressure (air pressure).
989.4 mbar - Intake manifold pressure (boost pressure)
0.0% accelerator pedal position.
Friday, October 16, 2009, 3:32:10:28245
VCDS Version: DRV 805.4
Data as of: 20090602.
Vehicle type: 3A - VW Passat B4.
Scan: 01 02 03 08 15 25 41
Address 01: Engine Control Module
Label file: DRV\028-906-021-AHU.lbl
Part number: 028 906 021 DD
Component: 1.9L R4 EDC SG D84
Encoding: 00000
Operating number: WSC 00000
No error codes found.
Readiness: Not Available.
The quick brown fox jumps over the lazy dog.
Translated on 19-09-2026, 5:15.
