Focus TDDI 90hp problem / P0235 boost pressure sensor & oil
calvin1805
Post07-12-2009, 22:22    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
habe einen 02er Ford Focus TDDI 90PS letzte Woche gekauft und vermutlich wars "die Katze im Sack"........ icon_sad.gif
After driving for a few kilometers, I noticed that the car wasn't accelerating properly.
Now I was reading.
Value / P0235
Component / Turbocharger boost pressure sensor - Circuit.
Is this a known defect, and where is the sensor located?
When I took the car in for a diagnostic check, I told the mechanic to please take a look underneath it, as I had noticed an oil leak on the rain-soaked street yesterday. The car had been parked for two days, and you could clearly see the oil film.
On the lift, you can clearly see that oil is being sprayed by the wind all the way to the middle of the car. It's not possible to tell where the oil is coming from. The mechanic suggested an engine wash might help, but I think that carries risks. Does anyone have any ideas about what it could be, or how I should proceed? Returning it isn't an option because it was a private purchase icon_sad.gif.[/quote]
Translated on 11-07-2026, 9:40.
Post08-12-2009, 7:58    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
aber ich denke die birgt Risiken.
What's the risk that you'll discover the oil is from a very undesirable source and that you've bought junk?
I'm sorry, I don't quite understand your statement. It's not like anyone is going to aim a pressure washer at all the connectors.
Unfortunately, I can't say anything specific about the error message, except that it could be related to either the boost pressure sensor, its wiring, or the turbocharger (including a stuck or defective control system).
Translated on 11-07-2026, 9:42.
calvin1805
Post08-12-2009, 9:23    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
The right-angled "turbo hose" is completely torn, and there's oil leaking all around it over a large area.
Translated on 11-07-2026, 9:43.
Post08-12-2009, 11:26    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
calvin1805 wrote:
Der rechtwinklige "Turboschlauch" ist komplett gerissen und in einem grossen Radius um diesen alles verölt.
That would be a lucky mistake... = Lucky break!
calvin1805
Post08-12-2009, 11:33    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
I'm just wondering how the engine can leak so much oil despite having a faulty turbo hose.
Even the inside of the hood is sprayed with paint.
Post08-12-2009, 11:46    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
Sometimes it really comes out strongly there, which is why that happens.
Translated on 11-07-2026, 9:44.
calvin1805
Post08-12-2009, 12:50    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
Could it be that the torn hose also caused this error when reading the fault memory, or is the turbocharger pressure sensor definitely defective?
Post08-12-2009, 13:35    Subject: Focus TDDI 90hp problem / P0235 boost pressure sensor & oil Quote
Okay, let's fix the obvious things first!
No new posts Ford Focus 1.6 TDCi - Error code P1181 General Tips
No new posts P0236 - Turbocharger Overboost Condition - Bank 1 Sensor 'A' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ARL Turbo Issues: Troubleshooting & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ford Focus TDDI: AGR Valve Problems & Whistling? Diesel Engine Technology
No new posts Ford Focus: Metallic Squealing Noise, 90HP TD Diesel Engine Technology
No new posts Ford TDDI: Rough Idle & Troubleshooting Diesel Engine Technology
No new posts Boost Pressure Sensor 1Z On-Board Diagnostics (OBD)
