hello
It's likely an old topic that comes up every year, and which has certainly been discussed extensively before.
On behalf of many Volvo drivers, I would like to ask for advice again – we are at a loss and don't know what to do next.
We're driving the AEL 5-cylinder engine from VW/Audi, and many people have really well-maintained vehicles, just like me, but they're not exactly the newest models anymore (around 300,000 km).
"I mean, my preheating system is working perfectly. Also, the glow plugs, injectors, etc. are well-maintained and properly adjusted. Many others report the same thing; a lot of money and effort is put into it, with glow plugs, injectors, etc. being replaced, but there's absolutely no change in cold-start performance."
Today, I recorded the following videos. The car had been parked overnight in temperatures around -18°C, and when I tried to start it this afternoon, the temperature was approximately -12°C.
First attempt, using a branded battery but it's old - it still lasts quite well, but it's not at 100% capacity anymore. You can hear how slowly it's spinning.
http://www.youtube.com/watch?v=C8RIrMaklwQ
The battery was dead. Then I installed the two-year-old Arktis, which had been fully charged overnight, take a look:
http://www.youtube.com/watch?v=0Eogl4mFN-M
At the bottom of the instrument panel, you can even see how old it is. Below the BC display, it's definitely icy inside.
Are there any clues, tips, or anything like that available? It seems that, according to our forum, many people are experiencing issues with this engine. How does Audi handle it? It could even be related to the engine control unit – we have an MSA15.7 here. I think VAG uses the EDC15. Does it work differently/better?
I personally used to own a car of the same model that was very poorly maintained, but it started perfectly. The only difference was that it was an automatic. So, is the starter motor engaged differently or better in automatic transmissions?
Thank you for the tips.
best regards, uwe
