Important note regarding the use of the VW 3099 for torque screws
haehnlein
Post28-05-2003, 13:55    Subject: Important note regarding the use of the VW 3099 for torque screws Quote
If any of you are using the Matra VW 3099 crankshaft holder icon_exclaim.gif to hold the crankshaft (e.g., when changing the crankshaft bolt), I strongly recommend replacing the two screws of the holder with high-strength (12.9) screws icon_exclaim.gif icon_exclaim.gif. Currently, 8.8 screws are installed. When tightening/loosening the crankshaft bolt, these two screws bent icon_evil.gif in my case. Fortunately, the crankshaft pulley was not damaged. I then inquired at an AUDI workshop, and a friendly employee informed me that the original 8.8 grade screws are far too weakly sized, and therefore, in the workshops, the 8.8 grade screws on the counter-holder are replaced with 12.9 grade screws icon_exclaim.gif.
____________
Kein Auto mehr!
Translated on 04-07-2026, 15:58.
No new posts A3 8L Screw Corrosion: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Graphics Card Failure After 8 Weeks? Troubleshooting. On-Board Diagnostics (OBD)
No new posts Possible tachometer tampering? On-Board Diagnostics (OBD)
No new posts Leak detection guide for the cooling system Diesel Engine Technology
No new posts Timing Belt for VW Transporter T4 2.5 TDI (Pre-2000) Diesel Engine Technology
