ESD Spacer Washers: Secure & Protect
Georg_G
2012 Volkswagen Golf
Post21-04-2010, 18:41    Subject: ESD Spacer Washers: Secure & Protect Quote
Hello forum,
I made a mess while disassembling the dust stoppers from an AEL.
The conical washer, which the retaining bolt presses against the retaining bracket, has fallen into the engine compartment, into a really difficult-to-reach spot.
Does anyone know if:
*) This washer can be purchased individually.
*) I could just use a regular (flat) washer. Probably not, though, right? Or does anyone know otherwise?
Best regards, Georg.
Translated on 06-10-2026, 4:53.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post21-04-2010, 18:51    Subject: ESD Spacer Washers: Secure & Protect Quote
I used two standard flat washers.
It has fulfilled its purpose until today icon_wink.gif.
Translated on 06-10-2026, 4:54.
Georg_G
Post21-04-2010, 21:09    Subject: ESD Spacer Washers: Secure & Protect Quote
Hi Klahaui,
Brave, brave. Isn't the conical washer important to ensure correct alignment of the nozzle holder? After all, the screw sits centered in the retaining bracket due to the conical shape.
But your good experience gives me hope icon_smile.gif.
Does anyone know the part number for something like that?
Post21-04-2010, 21:35    Subject: ESD Spacer Washers: Secure & Protect Quote
N 023 731 4, Target disc, 8.4mm, €0.50.
Translated on 06-10-2026, 4:55.
Post22-04-2010, 8:12    Subject: ESD Spacer Washers: Secure & Protect Quote
...or as a "quick fix," use two regular washers with a screw and nut inserted into the drill, and then bend/file them into a conical shape.
Translated on 06-10-2026, 4:56.
Georg_G
Post22-04-2010, 20:26    Subject: ESD Spacer Washers: Secure & Protect Quote
@Guste100:
Thank you for the spare part number. It will probably be very helpful to me.
I assume that's a VAG replacement part number? Or from Bosch? Well, it will probably be easy to clarify tomorrow with a phone call icon_smile.gif.
@Rainer:
It's also a good idea, but I'm not in a huge hurry. The car (a Volvo 850 TDI with already 300,000 km on the odometer) is just sitting there for now while the injectors are being replaced. That will take a few more days.
Translated on 06-10-2026, 4:57.
Wiesel
Post22-04-2010, 20:45    Subject: ESD Spacer Washers: Secure & Protect Quote
Hello Georg,
That is a VAG number.
Micha
Translated on 06-10-2026, 4:58.
No new posts BLS Label File: Guide & Download On-Board Diagnostics (OBD)
No new posts Fuel injectors for 130 PD? Diesel Engine Technology
No new posts LOGIN Code for AEL Diesel Engine Technology
No new posts Sensor technology for oil temperature Diesel Engine Technology
