1Z0 035 729: Compare Part Numbers 1Z0 035 729 E/F
Post23-04-2010, 13:30    Subject: 1Z0 035 729: Compare Part Numbers 1Z0 035 729 E/F Quote
I have a built-in.
Address 77: Telephone Label file: RKS\5P0-862-335.lbl
Part number SW: 1Z0 035 729 E HW: 1Z0 035 729 E
Component: FSE_2P8x H40 0190
Revision: 00000000 Serial Number: 00000005153158
Encoding: 0010411
Operating number: WSC 73430 790 00999
and a lying around.
Address 77: Telephone Label file: RKS\3C0-035-729.lbl
Part number SW: 3C0 035 729 F, HW: 3C0 035 729 F.
Component: Telephone 6809
Revision: 00012000 Serial Number: 0000000840021
Coding: 0016023
Operating number: WSC 05311 000 00000
The 3C alarm will not sound if you do not connect a phone case.
The Skoda brochure states "optional with or without shell."
So, is the 1Z better if you want to completely retrofit something, because you can save yourself the housing and the cables?
Translated on 23-07-2026, 12:02.
Post23-04-2010, 16:41    Subject: 1Z0 035 729 E vs. 3C0 035 729 F Comparison Quote
dieselmartin wrote:
The 3C will not ring if you do not connect a phone case.
If no one responds:
You could simply plug the Z1 connector into your car's 3C socket (move the passenger seat back, remove the plastic cover, and connect the plug). Then you can see if it really works without the casing.
I would guess that Skoda means: either with a charging cradle ("optionally with..."), or with a Bluetooth pairing adapter or touch adapter, or just the console without anything plugged in ("without a charging cradle"). But that's just my wild guess. You should check the Skoda owner's manual to see how to perform pairing without a charging cradle...
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 23-07-2026, 12:06.
