USB K-Line Adapter: Buy Now!
Nicklas
Post21-05-2003, 21:52    Subject: USB K-Line Adapter: Buy Now! Quote
Does anyone have any interest in a K-L USB adapter?
I've done a little research, and it would be quite simple to convert my adapter to USB, which would be quite useful with today's laptops.
Translated on 24-09-2026, 14:17.
joergs
Post22-05-2003, 5:46    Subject: USB K-Line Adapter: Buy Now! Quote
That would even be necessary, because most modern devices no longer have COM ports! icon_redface.gif
Post22-05-2003, 18:09    Subject: USB K-Line Adapter: Buy Now! Quote
Hi.
I agree with Jörg!
Are there already VAGCOM versions that can communicate via USB ports?
Avatar-Jan6K
Post22-05-2003, 18:43    Subject: USB K-Line Adapter: Buy Now! Quote
Hi Ulf,
"In my opinion, that's not the problem. You can simply map the entire signal to a virtual serial port using a small driver, and then pass that data to VAG-COM."
The fact that it's all being played via USB doesn't register at all with VAG-COM.
You'll have to convert it to a serial connection (meaning RS232, as USB is also a type of serial connection), because that's the only way to interface with the car's diagnostic interface.
Jan.
1Z5 CFHF / AHB H4D
Translated on 24-09-2026, 14:18.
Nicklas
Post22-05-2003, 19:37    Subject: USB Adapter: Buy Now & Save! Quote
Jan is almost right, but you need to do a little more than just a simple serial-to-serial conversion *g*.
The VCOM port isn't a big deal, I just think that USB might cause problems because USB is a single-master system, meaning only the PC can request data, whereas with a serial connection, anyone can send data. The smallest time interval is 1ms, which already means a delay of 2ms in the ideal case, considering a request from the VM Com driver (cyclically) and a response. I don't know how VAG Com handles this. I'll set it up and test it.
If it doesn't work, we'll still need to add a microcontroller (uC) to the adapter, which would be a more elegant solution and would also eliminate any timing issues.
Ideally, this should only be done with the help of VAG COM software.
I'll take care of getting everything I need and setting it up, and I'll report back here later.
Translated on 24-09-2026, 14:20.
vikinger
Post22-05-2003, 21:53    Subject: USB K-Line Adapter: Buy Now! Quote
I had the exact same problem. Since my new laptop only has USB ports, I first tried using a USB to Serial adapter, but VAG-Com couldn't find the connector that way. Then, recently, I bought a USB connector from DRV. It came with a special driver specifically designed for VAG-Com, and it works very reliably, and the communication is much faster than before. However, the catch is that it supposedly only works with XP.
Translated on 24-09-2026, 14:22.
morph
Post30-05-2003, 20:33    Subject: USB K-Line Adapter: Buy Now! Quote
I just saw on Ross-Tech that there is now a USB version of VAG-Com available --> http://www.ross-tech.com/vag-com/download/. Has anything developed regarding USB-to-OBDII interfaces yet? I wanted to connect my interface at a friend's place today, but we realized that his laptop also no longer had a serial port --> icon_confused.gif. Have a nice evening --> icon_wink.gif.
Translated on 24-09-2026, 14:23.
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts USB Diagnostic Adapter: Access Engine Control Unit On-Board Diagnostics (OBD)
No new posts Adapter Diesel Engine Technology
No new posts OBD2 adapter Diesel Engine Technology
No new posts Adapter for measuring return flow rates Diesel Engine Technology
