Turbocharger Differences: Same Part Number?
frebert
Post11-05-2010, 9:20    Subject: Turbocharger Differences: Same Part Number? Quote
Hello everyone,
Two weeks ago, my turbo suddenly changed its sound. Now, at a certain RPM, it sounds somewhat like a remote-controlled electric car icon_eek.gif.
Now I'm looking for a replacement, as it's likely to break down soon.
On my charger, there is the number 028145702D, and it is attached with one stud bolt to the turbo and two stud bolts to the exhaust manifold.
However, I've now found pictures in the auction house that have a "D" at the end, but they are attached with more than 3 studs on the exhaust manifold side, which doesn't fit my setup.
Is the number 028145702D not uniquely defined with regard to the attachment points?
Thank you!
Greetings.
Frebert.
1,9 l AFN mit Schick Wasser LLK im T3
Translated on 16-10-2026, 0:29.
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post11-05-2010, 10:42    Subject: Turbocharger Differences: Same Part Number? Quote
Could it be that the third stud bolt on the exhaust manifold has come loose due to rust or other natural causes, rather than the nut on the stud bolt itself?
I've experienced something like this before, and maybe that's exactly the point here.
Correct me if I'm wrong icon_wink.gif.
Best regards, Thilo.
Translated on 16-10-2026, 0:31.
vwSchrauber
Post11-05-2010, 12:19    Subject: Turbocharger Differences: Same Part Number? Quote
I believe there are 2 bolts on the turbine side and 1 bolt on the manifold side. Therefore, 2 bolts are screwed into the manifold, and 1 bolt is screwed into the turbine housing.
If the flange angle fits, then you can remove the studs, and improvise a little icon_wink.gif.
I would disassemble the chargers from the auction house before installation and carefully inspect them!
Translated on 16-10-2026, 0:32.
frebert
Post11-05-2010, 14:19    Subject: Turbocharger Differences: Same Part Number? Quote
klahaui wrote:
Could it be that the third stud bolt on the manifold has come loose due to rust or other natural causes, and not the nut on the stud bolt, as is usually the case?
I've experienced things like this before, maybe that's exactly the point here.
Greetings Thilo
No, that doesn't apply here!
Translated on 16-10-2026, 0:33.
No new posts Loader Compatibility: ALH, ASV, AHF, AJM, ATJ... Diesel Engine Technology
No new posts Audi Turbochargers: Differences Explained Diesel Engine Technology
No new posts [Poll] Egendöns Turbo Chargers: Reviews & Experiences Diesel Engine Technology
No new posts Bosch Engine Control Unit Number Diesel Engine Technology
