T5 2.5 TDI vs. T5.2 2.0 TDI: Towing Capacity Comparison
Post09-06-2010, 12:02    Subject: T5 2.5 TDI vs. T5.2 2.0 TDI: Towing Capacity Comparison Quote
Could it be that the T5.2 has been "derated" with respect to its towing capacity?
What can a 5-cylinder engine pull?
Translated on 05-07-2026, 13:46.
Post09-06-2010, 12:54    Subject: T5 2.5 TDI vs. T5.2 2.0 TDI: Towing Capacity Comparison Quote
"Ours can handle 2.5 tons... 3.5 tons is possible, but there are some specific models for that, which require the vehicle to be "upgraded" (as far as I know, this is not just a formal process, but also involves structural modifications) to increase the total weight. Additionally, a modified coupling system is also necessary."
The new 4-cylinder engines are also all specified with a towing capacity of 2.5 tons.
What do you mean by "deloaded"? What is the total weight of the vehicle and trailer combination?
Translated on 05-07-2026, 13:47.
Post09-06-2010, 14:09    Subject: T5 2.5 TDI vs. T5.2 2.0 TDI: Towing Capacity Comparison Quote
No.
I was thinking about using a 3T crankset with 2.5-inch tires.
Okay, so it seems like nothing has changed, at least not for the 132kW dual-fan model.
Translated on 05-07-2026, 13:48.
Post09-06-2010, 14:50    Subject: T5 2.5 TDI vs. T5.2 2.0 TDI: Towing Capacity Comparison Quote
Probably not...at least, not to my knowledge.
Engine: 85 kW gasoline engine.
unrestricted, incline up to 12% = 750 kg.
braked, inclines up to 8% = 2,300 kg.
braked, inclines up to 12% = 2,000 kg.
Maximum permissible gross weight on a gradient of up to 8% = 4,800 kg.
Maximum permissible weight on a 12% incline: 4,500 kg.
Engine: 173 kW gasoline engine.
braked, inclines up to 8% = 2,500 kg.
braked, inclines up to 12% = 2,500 kg.
Maximum permissible gross weight on a 8% incline = 5,300 kg.
Maximum permissible gross weight on a 12% incline: 5,300 kg.
Engine: 75 kW TDI diesel engine without a particulate filter.
braked, inclines up to 12% = 2,200 kg.
Maximum permissible gross weight on a 8% incline = 5,200 kg.
Maximum permissible gross vehicle weight on a 12% incline = 4,900 kg.
Engine: 75 kW TDI diesel engine with diesel particulate filter.
Engine: 77 kW TDI diesel engine.
Engine: 96 kW TDI diesel engine without diesel particulate filter.
Engine: 96 kW TDI diesel engine with diesel particulate filter.
Engine: 128 kW TDI diesel engine without diesel particulate filter.
Engine: 128 kW TDI diesel engine with diesel particulate filter.
...would likely be borderline or even unachievable icon_smile.gif when considering the total permissible weight.
Translated on 05-07-2026, 13:53.
Post09-06-2010, 15:55    Subject: T5 2.5 TDI vs. T5.2 2.0 TDI: Towing Capacity Comparison Quote
mhhh...the new one is lighter (150kg), faster (3 km/h), accelerates better to 100 km/h (0.7 sec), and consumes much, much less...according to the list icon_smile.gif.
It *must* be the better one, because a lower empty weight also allows you to carry significantly more. That reminds me, I need to check the actual empty weight. I would just have to clear all the debris out of it... mmm, maybe it will rain again soon, so I'll have something to do when I'm bored at home.
Translated on 05-07-2026, 13:59.
