Power Loss: Causes and Solutions
pafi11
2001 Volkswagen Golf
Post10-06-2010, 14:18    Subject: Power Loss: Causes and Solutions Quote
Hello!
Last week, I had a new head gasket installed in my Golf 4 (model year 2001) with an ASV engine and 110 horsepower.
(High water loss, high pressure in the cooling circuit)! However, before and now, I have very little power at around 1950-2100 RPM. Especially accelerating is quite difficult; it feels like there's a delay between pressing the accelerator and the engine responding. Above the mentioned RPMs, the power is normal or even more responsive. I cleaned the turbo and VTG during the head gasket replacement, so I can rule those out. I temporarily replaced the MAF sensor, but there was no improvement. A short-term increase in fuel injection didn't change anything, and the fuel injection start is also fine. I'm actually out of ideas; maybe someone here has a suggestion!
Sure, here's the translation:
"Thank you."
Translated on 24-10-2026, 7:04.
Post10-06-2010, 15:40    Subject: Power Loss: Causes and Solutions Quote
How many holes did the old head gasket have, and how many did the new one have? Switching from 1 to 3 could cause a moderately noticeable effect.
"It's more likely to me that the modifications caused leaks in the vacuum system, which may now be affecting its performance. Please check the measurement blocks 8 and 11 to see how the boost pressure regulation is working in the relevant speed range, for example, with the full throttle setting between 1200 and 2500 rpm."
I cleaned the turbo, or rather the VTG, at the same time as the Zkd replacement, so I can rule it out.
Is the VTG can installed correctly? Unfortunately, the holes have some play. Hopefully, the VTG rod hasn't been tampered with.
Translated on 24-10-2026, 7:06.
No new posts Octavia 1.8T TDI BMM: Power Loss Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss AUY 85 kW: Causes & Solutions Diesel Engine Technology
No new posts G3 TDI: Power Loss Troubleshooting Diesel Engine Technology
No new posts Power loss and ABS Diesel Engine Technology
No new posts Performance Loss Above 130 km/h (AJM) Diesel Engine Technology
