Timing Belt: Questions & Opinions
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
charlyfirpo
2013 Volkswagen Golf
Post13-07-2010, 18:01    Subject: Timing Belt: Questions & Opinions Quote
Hello.
Today, I visually inspected the timing belt after replacing it, and I noticed some areas where it appears to be "stitched" together.
There are some seams that are open, but I doubt those small threads will hold anything at all.
I've replaced several timing belts on PD engines before, but I've never noticed that issue.
My question is:
Does anyone know about this?
Is it concerning?
What is your opinion?
Timing belt changed approximately 90,000 km ago, using an original VAG kit including pulleys. I installed it myself.
A picture here" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusĂ€tzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema fĂŒr andere Leser nutzlos!
Bitte nutze 'Attachment hinzufĂŒgen' bzw. das Upload Forum hier.
/image.php?img=p7132711uf3s.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusĂ€tzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema fĂŒr andere Leser nutzlos!
/thumb/p7132711uf3s.jpg" class="responsive" alt="http://www.
/thumb/p7132711uf3s.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
Thank you for your responses.
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 02-08-2026, 12:02.
Octavia_4x4
Post13-07-2010, 19:51    Subject: Timing Belt: Questions & Opinions Quote
In my opinion, it looks absolutely brand new. These fibers on the side are from the cutting of the strap, and many of the straps I've sold have had the same thing.
I would be concerned if the shoulder seams started to pull or bunch up, and if there was any fraying.
But get some additional expert opinions here as well, which is absolutely fine.
Translated on 02-08-2026, 12:04.
charlyfirpo
Post13-07-2010, 20:12    Subject: Timing Belt: Questions & Opinions Quote
Thank you, Octavia_4x4.
Ich vergass noch zu sagen. ZR Breite gemessen exakt 30mm. Okay, then.
Translated on 02-08-2026, 12:05.
RedR32
Avatar-RedR32
1998 Volkswagen Golf
Post13-07-2010, 20:15    Subject: Timing Belt: Questions & Opinions Quote
Hmm... that's a bit strange. We should compare it to the same part from a new one to see if there are any differences.
I also believe that the gear ratio is appropriate in terms of power transmission.
The seams might just be a temporary way to hold the belt in place before the actual baking process that bonds it together.
reflexsilber met.
Karma: +1344 / -0   Thank you, like it!
Post27-07-2010, 10:08    Subject: Timing Belt: Questions & Opinions Quote
I had never seen anything this extreme before, but I had encountered a similar example with the same effect on the inside (after about 10,000 km). I didn't take any risks.
I would return the belt and try to get a flawless replacement. Otherwise, it's just 80 euros and wasted time.
"vg" translates to "very good" in English.
Translated on 02-08-2026, 12:07.
Uli S.
Post02-08-2010, 9:24    Subject: Timing Belt: Questions & Opinions Quote
charlyfirpo wrote:
Today, I visually inspected the timing belt, which had just been replaced, and noticed that it has some areas where it appears to be "stitched" together.
I recently bought a belt kit on eBay and wanted to return it immediately when I saw this seam (manufacturer: Dayco). However, I did some research beforehand, and apparently, that's a reputable manufacturer... Then I took a closer look at the belt and came to the same conclusion as you and Red32, namely that the threads are insignificant for its operation. In any case, I will install the belt.
Best regards, Uli.
Golf2 GTD AAZ, LLK, CYP
Bus T3 JX
2x Golf2 GTD/SB
alle fahren/fuhren ganzjÀhrig frauentauglich mit 100% Pflanzenöl
97er Golf 3 AFN, 70-100% Pöl
97er Golf 3 Variant AFN
96er Passat 35i AFN
Translated on 02-08-2026, 12:08.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt: Questions & Answers Diesel Engine Technology
No new posts Piston Animation: ARL - Your Opinion Needed Diesel Engine Technology
No new posts Polo 9n: Intercooler Modification 6L0805639A - Your Opinion Diesel Engine Technology
No new posts Timing Belt BLB - Replacement & Cost Diesel Engine Technology
