matthiasTDI96 Profi-Schrauber
27-08-2010, 8:31 Subject: |
Visually, it appears to be the same one, and it's also made in the US... I'll check the number later.
27-08-2010, 10:47 Subject: |
T5 has the engine code 03G906051A, it's the original engine, manufactured in 09/2007, with 77,000 km (approximately 47,000 miles) on the clock.
27-08-2010, 15:08 Subject: |
Based on my gut feeling, the 03G..A model likely came with MJ08.
"Our Golf has always had one, and I believe the Passat had a 03G before the 'secret exchange,' but without the 'A'."
Unfortunately, the other Passat from the same year has been in the workshop too many times, so there's little hope of finding an original, old sensor for it.
Alternatively, I could contact VW after the workshop campaign and ask if they could provide me with an old sensor for examination.
m; Transparency, Teamwork
Profile PM Garage |
bloesch Profi-Schrauber
Joined: 03/18/2005 Posts: 622 Karma: +16 / -0 Location: FL
27-08-2010, 21:53 Subject: |
However, you shouldn't swap them randomly.
In a dealership's service department, this type of replacement typically involves updating the engine control unit (ECU) software.
tlw After the update, a different differential pressure sensor (with or without A) will be required, as the signal appears to be inverted.
28-08-2010, 6:43 Subject: |
I performed a sensor replacement (I'm not 100% sure if I had the non-A version) and received an update from 1184 to 1881. The BMR code is 03G 906 016 EM.
It would be interesting to find a VOR-1881-BMR model that does not have the "non-A" designation.
Alternatively, I could check the BMP (Base Map Product), which is guaranteed to have never received an update (since 11/2006).
I'll see him tomorrow  .
Profile PM Garage |
vagtuning Guest
28-08-2010, 6:55 Subject: |
I am not aware of any mandatory pairing or requirement for an update related to the G450 replacement.
While both were sometimes done as part of a campaign.
'However, to my knowledge, there is no obligation. The 03G 906 051 A models just weren't very good.'
compared to the significantly better 076 models.
Based on the offset values, the 076 models typically have an offset of 0 plus or minus 10.
'The 03G models easily achieved speeds of around 80 km/h or more during their lifespan, and...'
could turn the motor on/off, retrain it, and they had a different value  .
28-08-2010, 7:49 Subject: |
UI
Those are my 03Gs... Yeah, they're really good.
Offset -10 after 128,000 km and +7 after approximately 30,000 km.
Who is willing to sacrifice a 076 model for disassembly?
Profile PM Garage |
29-08-2010, 15:07 Subject: |
Okay.
MJ 06 BMP (100,000 km, sensor from KW40/06) and 10 BMP (38,000 km) have the 03G..A part number.
Code: |
BMP Adresse 01: Motorelektronik (03G 906 021 NK)
11:00:51 Block 067: Partikelfilter (Abgaswerte I)
18.0°C Temperatur vor Abgasturbolader
24.0°C Temperatur im Partikelfilter
0.00 Druckdifferenz Partikelfilter
-15.30 Offset Differenzdruck
BMM 11:03:52 Block 067: Partikelfilter (Abgaswerte I)
30.0°C Temperatur vor Abgasturbolader
36.0°C Temperatur im Partikelfilter
0.00 Offset Differenzdruck
This allows me to confirm the aging process, and I must admit that I probably don't have any "not_A" versions, but can only provide versions with 4 "A"s. Transparency, Teamwork
Profile PM Garage |
