ZR Qualitätsunterschiede ? | Posts 32+
Go to page: Previous  1, 2, 3
gibt es Qualitätsunterschiede bei ZR Herstellern?
ja, benutze nur noch eine Marke
50%
 50%  [ 2 ]
ist egal, Hauptsache alles ist korrekt gemacht
50%
 50%  [ 2 ]
die Laufzeit ist unterschiedlich lang je nach Hersteller
0%
 0%  [ 0 ]
Total votes : 4
Post21-09-2010, 22:00    Subject: Quote
"In my own vehicles and also in vehicles belonging to customers, water pumps from Gats and SKF, featuring a metal impeller, have been installed frequently, and so far, there have been no issues."
Replacing the WPU (Water Pump Unit) during a ZR (Zylinderkopf) change is MANDATORY, even if the manufacturer doesn't explicitly require it.
A VPN isn't expensive!
Translated on 15-09-2026, 7:08.
Octavia_4x4
Post21-09-2010, 22:33    Subject: Quote
Okay,
I have always used only genuine VW repair kits because of the good trade prices, which are cheaper than the Contitech kits. However, in my experience, Contitech kits are just as good for other brands.
My 4x4 currently has a Bosch belt kit installed, which the workshop chose back then. It still looks perfectly fine after 50,000 km.
Translated on 15-09-2026, 7:09.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post21-09-2010, 22:45    Subject: Quote
and how do you achieve good EK (employee participation) rates at VW, Nora?
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
