Retrofit DPF (HJS brand), and engine oil with/without additives. Ash value
scrdel
Karma: +4 / -2   Thank you, like it!
2002 Volkswagen Passat
Post19-02-2011, 10:28    Subject: Retrofit DPF (HJS brand), and engine oil with/without additives. Ash value Quote
Hello, I drive a Passat 3 BG AVF with an aftermarket HJS cork (city filter) and I'm wondering, as my next oil change is coming up, whether I should consider the installed cork when choosing the engine oil?
I'm currently (and plan to continue) using Fuchs Titan Super Syn 5W-40 Plus without an oil level sensor (with fixed 15,000-mile intervals). VW itself specifies oils meeting the 507.00 standard for vehicles that come with factory-installed oil level sensors. I seem to recall that Aschewert, or perhaps HJS, mentioned that it might not be necessary.
Can anyone help me with something here?
I would like to continue using oils without WIV.
The search didn't turn up any results.
Best regards, Sven.
Post19-02-2011, 12:42    Subject: Retrofit DPF (HJS brand), and engine oil with/without additives. Ash value Quote
I'm doing the same thing as you! According to HJS, the type of oil doesn't matter because the filter, unlike its counterparts from the factory, is distinguished by its significantly different operating principle and mesh size.
So, you can continue using it if you like. In my case, the filter lasted for almost 100,000 km without any issues! I don't notice any of that http://www.hjs.com/de/173/0/seite_1/Fahrzeuge_&_Anwendungen/Transporter/Diesel-Partikelfilter/Fragen_&_Antworten/Technische_Fragen/technische_fragen.html.
scrdel
Post19-02-2011, 17:08    Subject: Retrofit DPF (HJS brand), and engine oil with/without additives. Ash value Quote
Hello, thank you for the quick information. Fortunately, I won't have to pour that WIV broth into my Passat.
Best regards, Sven.
Steffen W
Karma: +104 / -0   Thank you, like it!
Post19-02-2011, 21:50    Subject: Retrofit DPF (HJS brand), and engine oil with/without additives. Ash value Quote
The Passat in the signature has had the HJS filter installed since 50,000 km. I have also stuck with the 5W40 50501 oil. No problems whatsoever.
Passat Variant BGW 2005
Post20-02-2011, 15:43    Subject: Retrofit DPF (HJS brand), and engine oil with/without additives. Ash value Quote
No, apparently it's not necessary for aftermarket DPF systems that are designed to be installed without a closed exhaust system.
scroll tdi
Karma: +5 / -3   Thank you, like it!
Post21-02-2011, 8:48    Subject: Re: Retrofitting DPF (HJS brand here) and engine oil with/without additives. Aschew Quote
scrdel wrote:
Hello, I drive a Passat 3 BG AVF with an aftermarket HJS cork (city filter) and I'm wondering, as the next oil change is coming up, whether I should consider the installed cork when choosing the engine oil?
Best regards, Sven.
Please note: your Fuchs Titan Super Syn 5W40 Plus is a discontinued product. "Fuchs no longer manufactures it. 505.01 oils containing sulfur have become very rare."
Why not use a 505.01 in C3? For example. Catrol Turbo Diesel 5W-40
Furthermore, I'm not sure because section 507.00 has exceptions regarding backward compatibility. Sometimes, it seems like 505.01 is the better oil...
No new posts Debris and fragments in engine oil bind General Tips
No new posts Power loss without soot Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 CAAD ash value accidentally set to 0 Diesel Engine Technology
No new posts DPF Ash Reset for BMW 330d with Bavarian Technic On-Board Diagnostics (OBD)
No new posts Retrofit DPF Diesel Engine Technology
No new posts Retrofit DPF for older R5 TDI (AEL)? Diesel Engine Technology
