Golf 5 Key Programming: How-To Guide
chriskross
Post27-03-2011, 21:10    Subject: Golf 5 Key Programming: How-To Guide Quote
Hello!
Is it still possible to program keys using VCDS on a 2007 Golf 5, provided you have the necessary login credentials?
best regards, chris
A6 AFB
A6 BRE DPF
Translated on 30-09-2026, 4:14.
Post27-03-2011, 21:22    Subject: Golf 5 Key Programming: How-To Guide Translating...
[Translating...]
http://wiki.ross-tech.com/wiki/index.php/Immobilizer
mullemaus
Post28-03-2011, 0:29    Subject: Golf 5 Key Programming: How-To Guide Quote
2007 marked the transition from simply pre-programmed TX2x transponders to those that are pre-programmed specifically for each vehicle. icon_wink.gif If it's an originally ordered one, it will work with the known login. icon_wink.gif
Translated on 30-09-2026, 4:15.
chriskross
Post28-03-2011, 6:40    Subject: Golf 5 Key Programming: How-To Guide Quote
A6 AFB
A6 BRE DPF
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Polo 6N: Key Programming Guide On-Board Diagnostics (OBD)
No new posts Pairing key VW Crafter On-Board Diagnostics (OBD)
No new posts Passat 3c key programming On-Board Diagnostics (OBD)
No new posts VAG-COM: Key Programming with Version 409 On-Board Diagnostics (OBD)
