thom
29-03-2011, 10:51 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
Hello everyone,
"Yesterday, something strange happened to me. After overtaking a car, I suddenly lost all power. The engine was still running, but it didn't go into limp mode. It just didn't have any power. I initially thought it might be related to the VTG (Variable Turbine Geometry) and its adjustment, as I had recently replaced the hose to the vacuum actuator because it was worn. I then drove home like that. When I got home, I restarted the engine briefly, and to my surprise, everything was back to normal. This morning, I read the error codes."
16485 Air mass meter G70, implausible signal, error code P0101, -35-10---, interrupted.
17958 Boost pressure control differential p1550-35-00.
After that, I cleaned the mass airflow sensor and took it for a test drive. Still no power. I observed the boost pressure during the drive (using VAG-COM). Well, if you give it short bursts of acceleration, it does go up to 1 bar, but when driving normally, it only reaches 0.4 bar at 2500 RPM.
After that, I cleared the error codes and restarted the engine.
Unfortunately, the error persists.
17552 Air mass sensor G70: Disconnection/short circuit to ground detected.
I checked the connector, and I didn't see any broken wires.
I have to mention that the mass airflow sensor (MAF) doesn't seem to be original. It was replaced by the previous owner. I believe it should be a Bosch part, but I have a Pierburg one installed.
However, I drove 80,000 km with the Pierburg unit and only had to clean it once.
Can I check if the LMM is still producing reasonable values before I consider buying a new one?
Thomas.
Translated on 21-09-2026, 5:37.
Profile PM Email |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
29-03-2011, 11:26 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
/viewtopic.php?t=20765&highlight=pin assignment+MAF
Only measuring helps.
Translated on 21-09-2026, 5:40.
Profile PM WWW Garage |
a4_afn Blaumann
Joined: 02/02/2008 Posts: 127 Karma: +1 / -0 Location: Wien 1997 Audi A4 Free account, no CAN development support
29-03-2011, 14:39 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
"Since it already has a Pierburg mass airflow sensor, it should be fine as is."
Profile PM Garage |
thom
30-03-2011, 1:01 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
I logged data blocks 08 and 11 today.
Unfortunately, I was unable to create a visually appealing diagram.
Here's the translation:
"I also need to mention that the AGR (Abgasrückführung - exhaust gas recirculation) system is deactivated. After restarting the engine, and initially when starting to drive, nothing happens. However, if you fully depress the accelerator pedal in first gear, there's a surge at around 2500 RPM. I think that's when the VTG (variable turbine geometry) unlocks."
| Description: |
 Download |
| File name: |
Mappe3.xls |
| File size: |
141 KB |
| Downloaded: |
480 times |
| Description: |
 Download |
| File name: |
LOG-01-011-008-010.CSV |
| File size: |
5.14 KB |
| Downloaded: |
539 times |
Translated on 21-09-2026, 5:41.
Profile PM Email |
thom
30-03-2011, 23:37 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
Today, I sat down with my laptop next to the car again to see if it was really the mass airflow sensor.
I believe the LMM values are written to measurement block 3.
I think field 2 shows the target value, and field 3 shows the actual value.
In field 3, there's absolutely no activity; it's stuck at 550 mg/r, regardless of the speed.
That's why I'll also notice the increased fuel consumption, as I still have to drive the car every day.
And after 2200 revolutions, not much more happens.
Am I right in assuming that the mass airflow sensor (MAF) is defective?
Translated on 21-09-2026, 5:42.
Profile PM Email |
thom
31-03-2011, 12:27 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
Today, I measured the pin configuration of the mass airflow sensor (MAF) with the engine off. Everything seemed okay, except that one pin, which should have had 5 volts, was showing slightly over 7 volts.
Is that something to be ignored?
Thomas.
Translated on 21-09-2026, 5:44.
Profile PM Email |
31-03-2011, 12:29 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
Quote: | | Is that something to be disregarded?? |
No. It's likely a measurement error or a faulty wiring harness. The voltage regulator is less likely the cause, as that would also affect all other sensors, which would then receive 7V instead of 5V.
thom
02-04-2011, 7:21 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
Hello.
I installed a different LLM, and that was the problem.
As I found out from this forum, the Mercedes Sprinter now has a Bosch system again.
I actually have one more question: When the engine is idling, I'm getting a reading of 440 mg/h, which is quite a bit different from the target value (250 mg/h).
Is this still normal?
Thomas.
Translated on 21-09-2026, 5:45.
Profile PM Email |
Klausel Blaumann
02-04-2011, 20:41 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
Therefore.
Quote: | | What I still need to mention is that the EGR system is deactivated. |
is it "normal"?
Best regards, Klaus.
G III, 1x0 PS, Mj.98, 333 tkm, AFN
Polo 6R, TSI 110 PS
Translated on 21-09-2026, 5:46.
thom
03-04-2011, 9:07 Subject: Audi A4: Sudden Power Loss (Pierburg MAF Sensor) |
Yes, that's right, I could have figured that out myself.
Thank you again to everyone who helped me.
Thomas.
Translated on 21-09-2026, 5:47.
Profile PM Email |
