KG Druck as an indicator of engine defect?
Marco
Post17-07-2003, 10:39    Subject: KG Druck as an indicator of engine defect? Quote
Hello, tinkerers,
I am facing the decision of whether to purchase a machine with an AFB/AKN motor.
I have a lot of information here about insufficient compression pressure in individual cylinders.
read. My question: Is a measurement of KG pressure sufficient?
to assess the compression pressure of each cylinder.
diesel.gustav
Post18-07-2003, 22:45    Subject: KG Druck as an indicator of engine defect? Quote
Upon request, deleted.
No new posts Exhaust Temp: Engine Load Indicator? Diesel Engine Technology
This topic is locked, you cannot edit or reply. MWB13: Always an Indicator of Worn Injectors? On-Board Diagnostics (OBD)
No new posts ABS, no pressure Diesel Engine Technology
No new posts Pressure Setpoints for Gas Compressors Diesel Engine Technology
