AVF: Optimal Charge Pressure (Target vs. Actual)
joda79
Registered VCDS User
Post22-07-2011, 15:54    Subject: AVF: Optimal Charge Pressure (Target vs. Actual) Quote
Hello everyone,
I've been searching for a while now, but I haven't found what I'm looking for yet.
I've read in some forum posts that if something seems unclear, one should perform a comparison between two engines of the same design.
Unfortunately, I don't have a second AVF available for comparison right now.
Background:
I've only recently started driving a diesel car, and now I've finally managed to do a test drive using VCDS.
"I noticed that, especially in the lower RPM range (up to 1800 RPM), the difference between the desired and actual boost pressure is significant during acceleration, and the control system seems to have a certain amount of lag (see attachment)."
I would like to have this behavior evaluated and compared with your own measurements.
The question I have is whether everything is normal with the engine, or if there's something to be concerned about.
Thank you in advance.
Okay.
 File size:  51.33 KB
 Viewed:  3229 times
Autobahn_210720111.xls
 File name:  Autobahn_210720111.xls
 File size:  185.5 KB
 Downloaded:  477 times
Translated on 23-09-2026, 23:09.
Post22-07-2011, 18:03    Subject: AVF: Optimal Charge Pressure (Target vs. Actual) Quote
Except for the fact that it's once again a useless log, everything looks normal. icon_lol.gif
Please read Ulf's instructions on how to log data. Pointless pressing of the accelerator pedal achieves nothing.
Translated on 23-09-2026, 23:11.
No new posts P0011 - Camshaft Timing Delayed: Not Reached Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Power Loss: Air Mass/Boost/Timing OK? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI BKC: Boost Comparison - Chip Tuning with File On-Board Diagnostics (OBD)
No new posts Boost pressure/air mass, target vs. actual, mismatch (2.5... Diesel Engine Technology
No new posts Oxygen Sensor Fault? Boost Pressure & No Idea Diesel Engine Technology
No new posts TDI BKC: Boost Pressure - Stock vs. Tuned Engine Upload
