klahaui Profi-Schrauber
Joined: 08/13/2009 Posts: 1102 Karma: +125 / -0 Location: Vogtland, Land der Berge 2019 Volkswagen Golf Premium Support
10-08-2011, 12:57 Subject: |
voodoo wrote: | | I might be having a logical fallacy. But you don't really dissolve much with water, do you? |
klahaui wrote: | It's best to clean it thoroughly with some kind of cleaner and a lot of water.
I used to use cold cleaning agents and rinsed the part several times.
| Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
Deus Violentia Schrauber
10-08-2011, 13:26 Subject: |
It's best to fill the Kärcher with cold cleaner and rinse it using only 5 bar of pressure  . BKD GRF
AHF EBF
10-08-2011, 18:28 Subject: |
A garden hose will do. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
Joined: 04/12/2002 Posts: 18119 Karma: +801 / -0 Location: St.Gallen 2018 Volkswagen T6
10-08-2011, 18:48 Subject: |
The fats/oils present in the intake manifold can likely be removed much more easily using non-polar solvents (gasoline/diesel).
I don't think much of the water method; it just creates a mess.
Profile PM WWW Garage |
JSPatrick
Joined: 07/23/2011 Posts: 9 Karma: +0 / -0 Location: österreich
Registered VCDS User
10-08-2011, 23:18 Subject: |
hello
I can't tell you how to fix it, but I suspect the problem is with the first charger. The cooler has clogged the return line with soot!
The new or used loader didn't last as long without oil.
It's not normal for a used charger to fail after such a short time!
The same thing happened to me once before!
only with a new charger
Best regards, Patrick.
11-08-2011, 12:24 Subject: |
JSPatrick wrote: | hello
Best regards, Patrick |
Which return line is connected to the intercooler?
11-08-2011, 14:04 Subject: |
He's referring to the oil return line of the turbocharger. BKD GRF
AHF EBF
JSPatrick
11-08-2011, 14:07 Subject: |
Sorry!
I didn't express myself clearly!
I'm talking about the oil return line that goes from the turbocharger to the crankshaft.
Often, after a turbocharger replacement, the oil lines are cleaned.
The lubrication is often easily overlooked!
Furthermore, 1.1 bar is not really much pressure for the turbocharger; it should be able to handle more.
Hang in there!
11-08-2011, 16:18 Subject: |
But what does the LLK have to do with the turbo's return line?
And the second charger isn't actually defective;).
Greetings.
@jspatrik: There's a "Preview" and "Spell Check" button for a reason. Kaum macht man es richtig, funktioniert es!
Profile PM Garage |
JSPatrick
11-08-2011, 20:16 Subject: |
Hello.
Sorry! My mistake.
I will improve!
I haven't been around for very long.
Please translate the following text from German to English. Provide ONLY the translation, no explanations.
Best regards. Patrick.
