Interesting for all Passat owners from 1996 onwards. (Solution)
alexso
Post06-06-2002, 12:09    Subject: Interesting for all Passat owners from 1996 onwards. Quote
Recently, the car smelled extremely rotten.
Then it was gone again.
That sometimes happened again.
Now, I accidentally discovered that the drain in the water tank was completely blocked.
That means, the air that was sucked in was moist and foul-smelling.
The problem with that is... you can't see the process.
Only when the battery is removed can you access the drain.
The car is now exactly 4 years old. After such a period, this can always happen if you don't always keep the container clean.
Tip: In the drain opening, there is a thin rubber gasket that is simply inserted.
These are the ones I've removed.
This prevents any debris from accumulating on this relatively narrow and tight fitting.
Best regards, Alex
Ratings - Interesting for all Passat owners from 1996 onwards.
No new posts VW Central Locking: How to Program (2002+) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku alle VAG Fahrzeuge MJ 2002, Kühlmittelverlust Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Leaking oil lines, all V6 TDI engines up to mod... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Longlife Service: Every 15,000 km? On-Board Diagnostics (OBD)
No new posts Großer Turbo im A4/ Passat, AFN, AJM alle mit Serien VNT 15 Diesel Engine Technology
No new posts AAT/AEL: Interesting for more than just drivers? Diesel Engine Technology
No new posts STG Glitches Every 3 Minutes Diesel Engine Technology
