TDI Tuning Box: Performance & Power Boost
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » Diesel Engine Technology
Mitgliedsname00
Post29-07-2003, 11:31    Subject: TDI Tuning Box: Performance & Power Boost Quote
'Does anyone have a TDI tuning box? Ideally, one from Alpin. I have one with a 10-pin connector, but my A4 with 90 horsepower only has an 8-pin connector. How can I connect it? Only 4 pins are used to connect to the box (measured from the 10-pin connector to the box), and one wire needs to go to the MAF sensor. How is something like this configured? Or would you strongly advise against it?'
Has anyone possibly had a chip tuning done on a 90 horsepower engine?
Thank you very much.
Translated on 18-09-2026, 4:54.
Post29-07-2003, 11:48    Subject: TDI Tuning Box: Performance & Power Boost Quote
Sure, here's the translation:
"Here's a small tip:"
Use the search function
We've already discussed the pin assignments countless times, including the differences between the 10-pin and 8-pin versions.
We've already discussed all your other questions, and we've done so thousands of times.
Translated on 18-09-2026, 4:55.
Mitgliedsname00
Post31-07-2003, 8:54    Subject: 10-Pin Connector: Tuning Box & Adapters Quote
Okay, I have some of the information, but I'm still missing the pinout for the Alpin box. The cable for the mass airflow sensor (MAF) connects to pin 1 of the MAF, right?
Translated on 18-09-2026, 4:56.
