mhernach Guest
01-08-2003, 12:25 Subject: What could be causing the loading pressure issue? |
http://www.duw.de/DuWCarbox/ShowImage.aspx?ID=2153
Unfortunately, it's much too small... I can also send you the Excel file... Is this normal?
it's about ensuring that the target and actual charging pressure match...
where can I insert an image that is larger, or an xls file would be even better.
Best regards, Mike
Joined: 04/12/2002 Posts: 18092 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
01-08-2003, 12:31 Subject: What could be causing the loading pressure issue? |
Possible causes:
- Engine misfire, see fault codes
- Insufficient fuel supply to the engine
- Loading pressure control malfunction
- Turbocharger malfunction.
See Ulf's technical article on troubleshooting.
Hello, Rainer
Profile PM WWW Garage |
TDI Kraft ohne Ende Guest
01-08-2003, 20:12 Subject: What could be causing the loading pressure issue? |
Hello
Take a look below
'Loading pressure development and air mass'
There is a similar problem.
Please send me the Excel file.
Also, there were also discrepancies between the planned and actual figures.
Best regards, Ralph
