HI.
This probably applies more to Uwe.
Saving a collection of measurement values from a UDS ECU no longer indicates the source of those values.
Neither the filename nor the content indicate that I should.
Quote: |
Address 08: Climate Control/Heating (J255) Label file: RKS\5K0-907-044.clb
Part number SW: 5K0 907 044 BD, Part number HW: 5K0 907 044 BD.
Component: Climatronic
Part number: H14 0608
Revision: 00003001
Encoding: 0000000000
Operating number: WSC 01357 011 00200
ASAM Dataset: EV_Climatronic A01001
ROD: EV_Climatronic_VW46.rod |
here, which I have read.
Code: |
Sonntag,20,Mai,2012,13:57:50:31600
VCDS Version: RKS 11.11.3
Datenstand: 20120406
13:57:40
5.4 Nm Kompressorlast 003
75.6 % Gebläselast vorn 004
0.610 A Kompressorstrom; Istwert 008
0.600 A Kompressorstrom; Sollwert 009
33.2 % Kühlerlüfteransteuerung Istwert 010
33.2 % Kühlerlüfteransteuerung; Sollwert 011
Automatische Umluft aktiv Status Umluft 013
0 W/m² Sonnenintensität rechts 018
0 W/m² Sonnenintensität links 019
1000 /min Kompressordrehzahl 021
10.8 bar Kältemitteldruck 023
4.3 °C Temperatur nach Verdampfer 042
Am I doing something wrong, or is this a suggestion to improve VCDS?
