iiciaii
Registered VCDS User
13-05-2012, 11:19 Subject: Evaluate MWB 018 |
I'm having some trouble interpreting the log correctly. It was a longer trip involving highway driving, city traffic, etc. All load ranges were used, including disabling the torque limiter.
It's strange that I'm mostly getting zero readings, or that I'm only getting a "2" reading while I'm already driving.
Daniel.
| Description: |
| MWB 018 bei 03G 906 018 HB |
 Download |
| File name: |
LOG-01-018-xxx-xxx.CSV |
| File size: |
211.79 KB |
| Downloaded: |
539 times |
Octavia 1Z RS TDI EZ 2007
MKB: BMN
Translated on 04-07-2026, 6:03.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
13-05-2012, 15:37 Subject: Evaluate MWB 018 |
Have you ever moved the mouse cursor over the fields?
The tooltips actually explain the statuses.
0 means "error-free regulation," and 2 means "control during startup."
As it's not really a surprise.  Please make specific requests in the future. I also find many things funny. By the way, it is unnecessary to edit CSV files before uploading them.
Translated on 04-07-2026, 6:05.
Profile PM WWW Garage |
iiciaii
13-05-2012, 17:44 Subject: Evaluate MWB 018 |
I am familiar with VCDS and tooltips. Why am I getting a "2" (presumably a grade or error code) while driving?
Daniel.
MKB: BMN
16-05-2012, 10:35 Subject: Evaluate MWB 018 |
No idea  What's your problem?
PS: I could imagine that a regular calibration (zero-point calibration) might be the cause, as the value shifts from one cylinder to the next.
Translated on 04-07-2026, 6:06.
iiciaii
17-05-2012, 0:29 Subject: Evaluate MWB 018 |
My Octavia is having problems again. I took it to the workshop (VW) because I thought the turbo was broken: it was making a loud howling noise, similar to a siren. However, the mechanic said everything seemed to be okay. Boost pressure measurement also checks out using VCDS.
Only the intake manifold was replaced because it was leaking.
Right after that, I encountered a problem with the differential pressure sensor (I replaced it myself and configured it using VCDS).
Recently, it has started to exhibit a slight hesitation or stuttering at partial load, around ~1500 RPM. It's as if it momentarily "stutters" and then immediately returns to normal power. It's not strong, but it's very annoying.
The car is only driven for long distances (60 km twice a day, mostly on the highway).
Now I suspected it might be a PDE issue, so I logged everything. The values seemed okay so far. I'm just unable to interpret the MWB 18.
That car is driving me crazy. I want to use my old vacuum cleaner again  .
Daniel
MKB: BMN
Translated on 04-07-2026, 6:07.
hkss Blaumann
Joined: 12/17/2006 Posts: 171 Karma: +13 / -0 Location: Karlsruhe 2017 Skoda Yeti Premium Support
20-05-2012, 16:10 Subject: Evaluate MWB 018 |
I certainly can't help you with your problem, but I personally consider the MWB 18 value to be a pure indicator of the throttle cut-off.
For me, it's either 0 or 128.
Try running it with VC-Scope; you'll see the relationships and changes in the flow.
| Description: |
MWB 13 -
Kanal 1 - Einspritzm.-Abw.Zylinder 1 - VC-Scope Max:2 Min:-5
Kanal 2 - Einspritzm.-Abw.Zylinder 2 - VC-Scope Max:2 Min:-5
Kanal 3 - Einspritzm.-Abw.Zylinder 3 - VC-Scope Max:2 Min:-5
Kanal 4 - Einspritzm.-Abw.Zylinder 3 - VC-Scope Max:2 Min:-5
MWB 18 -
Kanal 1 - Magnetventilstatus Zylinder 1 - VC-Scope Max:129 Min:-1
Kanal 2 - Magnetventilstatus Zylinder 2 - VC-Scope Max:131 Min:-3
Kanal 3 - Magnetventilstatus Zylinder 3 - VC-Scope Max:133 Min:-5
Kanal 4 - Magnetventilstatus Zylinder 4 - VC-Scope Max:135 Min:-7
MWB 23 -
Kanal 1 - Schaltzeitabweich.Zylinder 1 - VC-Scope Max:3 Min:-94
Kanal 2 - Schaltzeitabweich.Zylinder 2 - VC-Scope Max:3 Min:-94
Kanal 3 - Schaltzeitabweich.Zylinder 3 - VC-Scope Max:3 Min:-94
Kanal 4 - Schaltzeitabweich.Zylinder 4 - VC-Scope Max:3 Min:-94 |
 Download |
| File name: |
LOG-03-013-018-023.CSV |
| File size: |
122.98 KB |
| Downloaded: |
435 times |
Translated on 04-07-2026, 6:09.
Profile PM Garage |
21-05-2012, 15:16 Subject: Evaluate MWB 018 |
"Jerks or interruptions during certain operating conditions are known to be caused by faulty wiring harnesses for the PD (piezo injector) control. I'm now unsure whether this issue affects not only systems with Bosch injection, but also those with Conti/Siemens PPD (piezo common rail) systems."
Translated on 04-07-2026, 6:10.
servusssss Blaumann
Joined: 11/14/2006 Posts: 159 Karma: +12 / -0 Location: Vlbg
21-05-2012, 20:55 Subject: Evaluate MWB 018 |
Okay, so with my PPD, the wiring harness was already completely messed up.
Therefore, I would just replace it; there's not much you can do to measure or repair it.
SG
iiciaii
02-06-2012, 13:36 Subject: Evaluate MWB 018 |
I recently spent a few days on the island of Sylt with my family. Before the trip, I replaced the Mass Air Flow Sensor (MAF) with a new one from Pierburg, suspecting it was the cause of a problem. However, the problem persisted even after the replacement. Before the trip, I filled the tank completely, and the problem then disappeared. The drive of approximately 380 kilometers was also trouble-free. Then, when the tank was about half full, it started happening again, which led me to suspect that my fuel pump might be the problem.
I then refilled the tank completely at home, but the problem persists. Today, the jerking is more pronounced during changes in load – more so than before. If you maintain the engine speed at around 2000 RPM while releasing the clutch by using a blip of the throttle, you'll hardly notice it.
Given the many different possibilities, I'll initially focus on the ZMS (steering motor), engine mounts, clutch, and PD (power distribution) wiring harness.
The car is really making me poor  .
I changed the diesel filter about 25,000 kilometers ago.
Daniel.
MKB: BMN
Translated on 04-07-2026, 6:12.
