Disconnect the control unit
andi
Post13-08-2003, 0:34    Subject: Disconnect the control unit Quote
I need to disconnect a 121-pin connector from the control unit (located under the windshield, in the center) for an equipment upgrade. What are the potential consequences of disconnecting this connection (e.g., errors, data loss, etc.)? Do I need to disconnect the battery?
'Thank you.'
Post13-08-2003, 9:15    Subject: Disconnect the control unit Quote
If the plug is secured by plastic sliding rods, icon_cool.gif be careful not to break anything off (do not apply force).
Apart from any potential outbursts or the issue mentioned above, nothing much should happen if you disconnect the engine control unit (I assume that's what you've done).
However, when working on electrical components, it's always a good idea to disconnect the battery (and remember the radio code).
andi
Post13-08-2003, 12:21    Subject: Disconnect the control unit Quote
Thank you for your reply. My radio is code-free; I was just thinking about potential issues with the original electronics.
I've already noticed that the connector seems to be locked in place with some kind of 20-point locking mechanism. Is there any clever trick to get it open?
Post13-08-2003, 12:33    Subject: Disconnect the control unit Quote
When assembling, use patience and avoid applying excessive force.
andi
Post13-08-2003, 16:46    Subject: Disconnect the control unit Quote
It worked, I successfully identified the pins for the GRA cable, and everything is still icon_wink.gif.
'Thank you.'
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AMF - NW, disconnect Diesel Engine Technology
No new posts Timing belt replacement, ALH fuel pump disconnection. Diesel Engine Technology
No new posts ECU 1Z for AHU Engine: Compatibility & Info On-Board Diagnostics (OBD)
No new posts AFN control unit On-Board Diagnostics (OBD)
