Audi 80: Cheap Parts, No Information?
wizabocka
Post06-06-2002, 16:57    Subject: Audi 80: Cheap Parts, No Information? Quote
Hi!
I came across this tip and was initially very excited, but then the disappointment set in:
ECU removed -> 54-pin connector???? No early injection functionality?
Then I wanted to increase the quantity, but it seems there are no cables with 8 or 10 pins available; I only have a cable with 3 pins.
What am I doing wrong?
I have some basic knowledge of electronics, but if I don't know which cables to use, I can't do anything.
Please clarify!
Translated on 09-08-2026, 3:48.
Post06-06-2002, 17:08    Subject: Audi 80: Cheap Parts, No Information? Quote
http://www1.buch24.de/Audi_80/Avant/Diesel_TD/TDI_ab_August_91_Jetzt_helfe_ich_mir_selbst/1001-7441424/3-143515-11.html
I would like to close this topic.
Translated on 09-08-2026, 3:49.
wizabocka
Post06-06-2002, 18:38    Subject: Audi 80: Cheap Parts, No Information? Quote
Yes, great!
But is it even possible? I just need a YES or NO answer, and that would be enough for me.
'Thank you anyway, but if you're going to create a guide like that, you shouldn't be surprised when people encounter problems while using it...'
Translated on 09-08-2026, 3:50.
Post06-06-2002, 19:58    Subject: Audi 80: Cheap Parts, No Information? Quote
You need to know yourself what components are installed in the engine compartment. If you have a 4-cylinder TDI engine, measure the resistance between pins 1 and 2, and 2 and 3 on the injector pump connector. If you measure approximately 60 ohms, you have an inductive feedback sensor. Otherwise, the resistances of the "10 cent tuning" likely need to be adjusted. -> YES.
Translated on 09-08-2026, 3:51.
wizabocka
Post07-06-2002, 20:01    Subject: Audi 80: Cheap Parts, No Information? Quote
You're right, I was totally blind! But the photo misled me because you have a transverse engine, so I thought the connector would be under the cover. Then I expanded my search area, and sure enough, I found it. I'll definitely try it out.
Oh yes, are you referring to the needle lift valve on the 3-cylinder engine? (At least with a longitudinal engine, it's the third one.) (I know, I'm so ignorant... icon_wink.gif)
The adjustment of the fuel injection start time is actually the more interesting topic for me!
Thank you for your understanding!
Translated on 09-08-2026, 3:52.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Passat 3BG AVF: No Power Until 2200 RPM Diesel Engine Technology
No new posts Hard Drive Failure: No Performance, Zero Data Diesel Engine Technology
This topic is locked, you cannot edit or reply. 10 Cent mal anders!?? Diesel Engine Technology
No new posts 10 Cent Nebelwand Diesel Engine Technology
