Actions speak louder than words | Posts 32+
Go to page: Previous  1, 2, 3
98er_alh
Post21-07-2003, 21:50    Subject: Actions speak louder than words Quote
I also have to add my two cents to this discussion.
Ich habe bei meinem ALH wegen des Anschaffungswiderstandes vom VW LMM die DC Variante auf Verdacht probiert und es geht seit 2 Monaten sehr gut. Bis ca. 1700U/min bringt er er zwar nicht die erforderlichen Werte aber wenn man vorher einen kaputten LMM hatte fühlt man sich trotzdem wie im 7. Himmel. Etwas Ausgleich brachte ein verirrtes Blech in der AGR. Seit 2 Tagen kann ich auch mir mit VAGCOM das ganze auch gut anschauen. Perhaps I will also drill a hole (as mentioned before) in the mass airflow sensor to achieve slightly higher values.
Best regards, Andreas.
Translated on 23-07-2026, 2:52.
Stefan .
Post22-07-2003, 18:29    Subject: Actions speak louder than words Quote
It should be relatively easy to 'replace' a faulty mass airflow sensor using a simple adder circuit built with an operational amplifier.
The values of a properly functioning LMM (Ladedruckmesser) are known; in principle, one could simply increase these values using an adder circuit. All that needs to be done is to increase the voltage supplied by the defective LMM.
If the adder is made adjustable, it offers the additional advantage that the output signal can be further adjusted, allowing the mass flow meter to be used 'to its absolute limit' before it actually needs to be replaced.
I only know the characteristic curves of a new and a defective mass airflow sensor, but that might be something we can figure out. If necessary, we'll have to modify the circuit a bit so that the values can be adjusted.
icon_wink.gif Stefan.
Translated on 23-07-2026, 2:53.
olbetec
Post23-07-2003, 10:18    Subject: Adaptation channel to compensate for the LM difference? Quote
Has anyone ever considered maximizing the LMM adaptation channel to correct the LMM?
What is the adjustment range in mg/H for the mass flow controller (MFC) adaptation?
Stay cheerful.
Fabia I TDI, EZ06/01 (1,9/74kW, ATD)
Octavia II TDI DSG EZ11/06 (2,0/103kW, BMM)
Translated on 23-07-2026, 2:55.
Post23-07-2003, 13:13    Subject: Re: Adaptation channel for compensating for the LM difference? Quote
olbetec wrote:
Has anyone ever considered using the DC-LLM and fully opening the LLM adaptation channel to correct the LLM in some way?
Hi.
This adaptation is (at least with AFN) primarily intended to adjust the EGR rate.
If the mass airflow sensor (MAF) is dirty and reports an insufficient amount of air, the EGR rate will also be reduced accordingly (see the MAF technical article).
The adaptation process allows for setting a lower target LMM value to compensate for the EGR control error.
"High emissions are a concern, but as far as I know, there's no adaptation to compensate for the power loss caused by the mass airflow sensor (MAF)."
Translated on 23-07-2026, 2:56.
Happy-Phantom
Post27-07-2003, 9:35    Subject: Actions speak louder than words Quote
Two days ago, I installed a mass airflow sensor (MAF) from DC (DC part number: A 611 094 00 4icon_cool.gif.
My car (a Seat Alhambra 1.9 TDI-PD with 115 horsepower, manufactured in 2001 and with 58,000 km mileage, equipped with a Bosch mass airflow sensor: F00C 2G2 056) had the usual performance issues.
Unfortunately, I don't have a suitable OBD2 interface for my laptop, so the replacement was done based on suspicion after I had ruled out other possibilities (such as the pressure sensor, linkage, etc.).
I can't check the values right now, but my subjective impression is extremely positive. In my opinion, the car now performs even better than before (before the loss of power icon_smile.gif). Definitely, it drives with approximately 190 km/h on the speedometer, which is about 10 km/h faster than after purchase (when it was a new car).
Since the EGR valve is apparently defective icon_wink.gif, the car already hesitates quite a bit when accelerating below 1500 RPM.
The engine is running smoothly again, pulling strongly across the entire RPM range – from 1500 to 4000 RPM – with an even stronger pull between 1850 and 2800 RPM, without any jerking or hesitation, just as it should.
The maximum speed is now easily reached again (previously it was only 145 km/h).
Conclusion: I can only recommend installing a mass airflow sensor (MAF) from DC. Especially since the price is only 1/4 of the Bosch part, and the DC one is also supposed to last longer. It also looks much cooler than the MAF from DC icon_smile.gif.
Den Stecker habe ich übrigens nur einfach draufgesteck ohne anzubohren o.ä. DHe holds it.
Maybe it will help someone icon_smile.gif.
Happy-Phantom.
Translated on 23-07-2026, 3:00.
uma
Post14-08-2003, 19:55    Subject: Mass airflow sensor in the 65kW AJT is faulty - Can it be replaced with a DC version? Quote
In my T4 with a 65kW TDI engine (engine code = AJT), manufactured in September 1999, the Bosch mass airflow sensor (MAF sensor) is faulty icon_cry.gif.
VW Part No. 028 906 461.
Bosch part number: 0 281 002 216.
Can this be replaced with the Daimler-Chrysler (DC) Low Mount Manifold (LMM) from Pierburg?
Number A 611 094 00 48.
replace it? Or does another alternative work?
Has anyone had any experience with this?
What needs to be considered (e.g., modifying the plug)?
I am grateful for any of your tips!
Uwe M
Translated on 23-07-2026, 3:03.
felix
Avatar-felix
Post15-08-2003, 12:33    Subject: Actions speak louder than words Quote
@ Thomas K
Sorry for the late reply, even though it might already be answered.
During my annual review, I found the following LMM (likely meaning "local market manager" or a similar role):
VW Part Number 071 906 461 A.
Bosch Part No.: F00C 2G2 027
Gruß Felix
E91 330d, 1/2009
Translated on 23-07-2026, 3:05.
uma
Post18-08-2003, 15:47    Subject: Subject: Mass airflow sensor in the 65kW AJT is faulty - Can a DC replacement be used? Quote
Uwe M.
I installed the DC-LMM (part number: A 611 094 00 4icon_cool.gif this morning.
It worked without any problems; the connector basically fits perfectly. However, it doesn't have any recesses for the locking tabs on the side of the DC-LMM adapter.
I still need to drill those.
I then drove 20 kilometers without any problems.
My impression is that the top speed is exactly the same. Subjectively, there's a very slight decrease in acceleration at lower RPM compared to the brand new VAG (Bosch) mass airflow sensor that was previously installed.
'It doesn't bother me much, but a difference of 62 euros versus 250 euros is quite a significant argument. Besides, if the new VAG mass airflow sensor had degraded as quickly as the old one, then performance equality would have been achieved sooner or later anyway. My T4 only had 48,000 kilometers on it!'
My friendly VAG workshop is readily accepting the new VAG mass airflow sensor for return...
I'm going on vacation this Saturday, and I'll share my experiences then.
Uwe M
Translated on 23-07-2026, 3:08.
No new posts Golf 1J: Grinding Noises in All Gears Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Merry Christmas to all Diesel Engine Technology
No new posts MWB23: Cylinder readings -60 to -80 Diesel Engine Technology
No new posts MWB23: -60 to -80 on all cylinders, Log Upload
No new posts Audi 100 (C4) TDI: Engine Misfire Troubleshooting Diesel Engine Technology
