Top speed of Roomster 1.4i now only 120 km/h
Thomas_Alt
Post12-11-2009, 19:23    Subject: Top speed of Roomster 1.4i now only 120 km/h Quote
Hello everyone,
I'm having a small problem with a Roomster, manufactured in February 2008, with approximately 60,000 km on the odometer. Engine: 1.4i with 63 kW (BXW).
The speedometer maxes out at around 120 km/h. Maybe you can reach 140 km/h going downhill. However, it's officially registered for a top speed of 170 km/h. The error memory does not contain any meaningful information (mixture occasionally too lean - occurred once).
Oh yes, the vehicle has been converted to run on autogas, but it has the same problem with gas as it does with gasoline. The compression of all cylinders is between 13 and 14 bar.
Does anyone here have any ideas?
Ah yes, the accelerator pedal potentiometers are changing simultaneously.
Thomas.
Post12-11-2009, 19:33    Subject: Top speed of Roomster 1.4i now only 120 km/h Quote
My wife's car once had the floor mat slip under the gas pedal. icon_cool.gif
Does the accelerator pedal position reading in the relevant measurement block correspond to "full throttle"?
Thomas_Alt
Post28-11-2012, 7:47    Subject: Top speed of Roomster 1.4i now only 120 km/h Quote
Unfortunately, I hadn't posted my result yet: The catalytic converter at the manifold had dissolved, thus clogging the second catalytic converter icon_sad.gif.
Conclusion: Both CATs are defective (could no longer be blown out).
It's working again now.
Thomas
Post28-11-2012, 9:12    Subject: Top speed of Roomster 1.4i now only 120 km/h Quote
Thank you for the feedback! If available, a data block containing the mass airflow rate would have been interesting.
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VAG-COM: Connection lost above 120 km/h? On-Board Diagnostics (OBD)
No new posts Skoda Roomster: Key Programming (Immobilizer) On-Board Diagnostics (OBD)
No new posts GRA errors after AHK installation, Roomster 2010 On-Board Diagnostics (OBD)
No new posts Top Speed: How Fast Can You Go? Diesel Engine Technology
