TDI Engine with Gas Transmission: Possible?
Jan03
2010 Volkswagen Polo
Post25-08-2003, 7:10    Subject: TDI Engine with Gas Transmission: Possible? Quote
Hello.
I'm planning to replace the gasoline engine (ABS motor, 90 hp) in my Golf III with a TDI engine (1Z). My problem is that I am only allowed to replace the engine itself (for tax reasons, I live in Denmark) icon_cry.gif. Does anyone know if the 90 hp TDI can be connected to a transmission from the 90 hp gasoline engine? The gasoline engine has a mechanical clutch (210mm). Can the mechanics handle the larger clutch of the TDI, or will I have to replace the clutch (or switch to hydraulic actuation)?
/Jan
Translated on 27-07-2026, 0:19.
B4-TDI
Post25-08-2003, 11:59    Subject: TDI Engine with Gas Transmission: Possible? Quote
Hi there.
The clutch actuation of the Golf transmission works completely differently. The release bearing is not located in the bell housing, but at the other end of the transmission and presses on a rod, which in turn presses on the pressure plate. The construction of the clutch itself is also 'reversed.' The only option would be to install a reinforced clutch and use the starter motor from the 1.9 TDI engine, although I'm not sure if it will fit the flywheel's teeth. Also, the transmission ratio is much too short. The gasoline engine reaches approximately 180 km/h at 6000 rpm, while the TDI only reaches about 120 km/h at its maximum speed of around 4200 rpm. Therefore, normal driving is impossible.
Gregor
Translated on 27-07-2026, 0:20.
joergs
Post25-08-2003, 12:06    Subject: TDI Engine with Gas Transmission: Possible? Quote
I also think it will fail due to the transmission, as the transmissions for the TDI and gasoline engines likely differ in their gear ratios alone.
Translated on 27-07-2026, 0:22.
Jan03
Post25-08-2003, 19:51    Subject: TDI Engine with Gas Transmission: Possible? Quote
Okay, I understand about the translation. This just needs to work until I get through the technical inspection (TÜV). After that, I'll definitely install the TDI transmission.
It doesn't sound like there's a possibility icon_sad.gif icon_sad.gif. Can't I attach the flywheel, including the clutch from the ABS motor, directly to the TDI crankshaft?
/Jan
No new posts Ford with TDCi engine: rough running, stalling General Tips
No new posts Doku Caddy 9K9: Engine Stalling, Error Code 1268 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Engine starts, then immediately stalls. Model: ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 10Cent Tuning for 1Z Engine (Golf, manufactured 6/95, 90H... Diesel Engine Technology
No new posts Engine won't start, stalls at traffic lights Diesel Engine Technology
This topic is locked, you cannot edit or reply. Golf 3 AEE Engine: Marelli - RPM Fluctuations On-Board Diagnostics (OBD)
No new posts Engine Rattling When Cold - Common Causes Diesel Engine Technology
