Coolant Leak in Cold Condition (AFN)
oldewurtel
Post13-01-2013, 18:55    Subject: Coolant Leak in Cold Condition (AFN) Quote
Hello fellow enthusiasts,
During the major service (270,000 km), I discovered that there was a drop of coolant hanging at the junction of the coolant hose to the ZK flange (the one with the temperature sensor) when the engine was cold! icon_rolleyes.gif
Upon closer inspection of the leak, by pressing and twisting the hose, several drops appeared icon_idea.gif.
Since the coolant level has hardly decreased in recent years, the leak in the system must be relatively small.
'I usually check all the clamps for tightness during each maintenance cycle, and the clamp in this particular location has always had a 'hard' stop (meaning it doesn't have that 'soft' feeling when tightening).'
I then installed a new hose clamp, which could also be tightened again with that same soft feel.
The examination of the original clamp revealed a small imperfection (indentation marks) precisely in the 'tightened position,' which prevented further tightening with normal force.
Due to the expansion of the hose when the engine is warm, the entire thing was sealed again.
So: Hose clamps should always have this soft contact point (which actually makes sense, right?). icon_exclaim.gif
Best regards, Oldi.
Translated on 17-09-2026, 17:33.
Karma: +1344 / -0   Thank you, like it!
Post13-01-2013, 20:13    Subject: Coolant Leak in Cold Condition (AFN) Quote
If a coolant hose connection leaks, there's usually coolant or crystallized residue from the additive between the hose and the connector. The only solution is to remove it and clean it, and if necessary, replace the hose. VW specifies a torque of 2 Nm for tightening the hose clamps. In my opinion, that's too low. Tighten it by feel, until it's snug. That's probably what you mean by a "soft" tightening.
Translated on 17-09-2026, 17:35.
No new posts Golf 1J: Gear Shift Problems in Cold Weather Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T6 TDI Coolant Leak Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Coolant Loss, AGP, AGR, AHF, ALH, AQM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tapping Noise in Cold 1.9 TDI PD Engine: Problem? Diesel Engine Technology
No new posts Klackern bei kaltem Motor..AAT Diesel Engine Technology
No new posts Engine RPM at Cold Start: What's Normal? Diesel Engine Technology
No new posts Boost Pressure: Cold Engine & >2500 RPM Diesel Engine Technology
