Oil Temperature Sensor 2.5A AT
disel-fritze
Post30-08-2003, 18:24    Subject: Oil Temperature Sensor 2.5A AT Quote
HELLO EVERYONE,
I've owned an Audi A6 TDI with 85 kW for a year.
THE OIL TEMPERATURE GAUGE EXCEEDS 130 DEGREES AT FULL LOAD (180-200+), BUT RETURNS TO NORMAL WHEN DRIVING SLOWER.
'HOW HIGH CAN IT GO? CAN I DRIVE IT AT THAT SPEED FOR A LONG TIME (ON THE AUTOBAHN)?'
WOULD IT BE NECESSARY TO UPGRADE THE OIL COOLER (FOR AN A6-AEL WITH 103 kW)?
I would like to install another chip (for use in a basement).
DOES ANYONE HAVE A COMPARISON?
GREETINGS, FRITZ.
Translated on 19-08-2026, 13:13.
libelle
Post31-08-2003, 15:44    Subject: Oil Prices: Current Trends & Forecasts Quote
Hello from South Africa.
My German is not very good.
'Oil temperatures of 130 degrees Fahrenheit shouldn't be a problem. I would assume Audi is using an oil with a synthetic base.'
Oil: BMW states that oil temperatures of 130 degrees Celsius are not a problem; however, above that temperature, an oil cooler should be installed.
Best regards, Werner.
Translated on 19-08-2026, 13:15.
