Hello everyone,
Unfortunately, I've had a different software installed on my 1.9 PD AVF engine with 415 Nm for the last 30,000 km, and since then, the clutch has been slipping... sometimes more, sometimes less, and sometimes not at all.
I'm surprised it even manages to get going. As I said, it usually only slips in 5th and 6th gear when I want to accelerate more forcefully uphill on the highway.
Even when downshifting from 2nd to 1st gear, you can now hear a loud knocking sound.
I suspect the ZMS is now signing off.
Now I need to replace the clutch, and I'm considering switching to the Valeo 4K kit.
I've now spent 10 hours online and have occasionally read that the kit fails after about 20,000 km.
Now the question is whether anyone here has experience with the Valeo 4K kit...
The following kit would be suitable for my vehicle:
My vehicle:
A4 B6, year 2002, 1.9 AVF engine, 185,000 km (approx. 115,000 miles), primarily highway miles.
Clutch kit + flywheel VALEO - Ref.: 835026
VALEO 4KKIT
Diameter 1 [mm]: 240.9
Technical Information Kit 4P (3-component kit + rigid flywheel).
Version DBR
Diameter 2 [mm] 240.
Number of teeth: 23.
Hub profile 21.8.
Hub profile 24.3.
with flywheel
Price-wise, it's quite interesting, as you can find it online for just €380.
http://www.autoteilemann.de/kupplungssatz-vw-553391.html
The original LUK kit, including the flywheel, would cost approximately €520.
http://www.profiteile.de/index.php/product/600+0040+00/6/luk-kupplungssatz
I hope someone can help me with this decision.
