Audi A4 - How can I turn off/disable the daytime running lights?
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
mani38
Karma: +0 / -1   Thank you, like it!
2004 Volkswagen Golf
Registered VCDS User
Post22-06-2013, 13:51    Subject: Audi A4 - How can I turn off/disable the daytime running lights? Quote
I would like to turn off or disable the daytime running lights. I've already done an auto-scan of the car, can someone please help me?
Saturday, June 22, 2013, 2:39:26:56861 PM.
VCDS version: RKS 11.11.5
Data as of: 20130111.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 8E - Audi A4 B6/B7.
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Vehicle Identification Number (VIN): WAUZZZ8E98A016072. Mileage: 102,320 km.
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Feld und lÀsst das Gras sanft wiegen. Es ist ein wunderschöner Tag."
The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze blows through the field, causing the grass to sway softly. It's a beautiful day.
Address 01: Engine - Label file: Routing error!
Part number SW: 03G 906 016 GD, HW: 03G 906 016 GD.
Part number: R4 1.9L EDC G000SG 9897.
Revision: --H05--- Serial Number: XXXXXXXXXXXXXX
Encoding: 0000071
Operating number: WSC 00276 219 76326
VCID: 6BDEB3744A5BED40E4E
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brakes
Label file: RKS\8E0-910-517.lbl
Part number SW: 8E0 910 517 H, HW: 8E0 614 517 BF.
Component: ESP8 FRONT H06 0140
Revision: 00000000 Serial Number: 00000000000000
Coding: 0004401
Operating number: WSC 06325 000 00000
VCID: 2C5C70688FD52A78AD4
Address 08: Climate Control/Heating Label file: RKS\8E0-820-043.lbl
Part number: 8E0 820 043 BR
Part: A4 Climate Control Unit, part number 3233.
Encoding: 00000
Operating number: WSC 00000
VCID: 72E0AE103E713C88278
Address 09: Body Control Module
Label file: RKS\8E0-907-279-8EC.lbl
Part number: 8E0 907 279 N
Component: Internal Load Module NDL 0907.
Coding: 00012
VCID: 3D7A4D2C37AFB3F00AA
Address 15: Airbag
Label file: RKS\8E0-959-655-94.lbl
Part number SW: 8E0 959 655 G, HW: 8E0 959 655 G.
Part number: Airbag 9.41 H14 4230.
Revision: 91H14423 Serial Number: 0036M0G8PMEU
Encoding: 0030612
VCID: 3B7E43347ABBBDC034E
Address 16: Steering wheel
Label file: RKS\8E0-953-549.lbl
Part number: 8E0 953 549 Q
Component: Steering column module 0701.
Coding: 00041
VCID: 418231DC4B57D7106E2
Address 17: Combination Instrument
Label file: RKS\8E0-920-9xx-8EC.lbl
Part number SW: 8E0 920 901 H, HW: 8E0 920 901 H.
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Encoding: 0006108
Operating number: WSC 00276 219 135726
VCID: 2A507670862134485F8
Address 46: Comfort System
Label file: RKS\8E0-959-433-MAX.lbl
Part number: 8E0 959 433 CM
Component: Comfort Device T23 4236
Encoding: 06752
VCID: 7EF88A207A2968E8530
Subsystem 1 - Part number: 8E1959801H
Component: Törsteuer.FS BRM 0606
Subsystem 2 - Part number: 8E1959802H
Component: Törsteuer.BF BRM 0606
Subsystem 3 - Part number: 8E0959801E
Component: Törsteuer.HL BRM 0606
Subsystem 4 - Part number: 8E0959802E
Component: Törsteuer.HR BRM 0606
Address 56: Radio
Label file: RKS\8J0-035-1xx-56.clb
Part number SW: 8E0 035 186 AK, Part number HW: 8E0 035 186 AK.
Component: R Concert2+ H03 0240
Revision: 00H03000 Serial Number: AUZ1Z3G1821009
Encoding: 0010211
VCID: 70E4A418607D0E98D1C
Address 76: Parking Assist
Label file: RKS\8E0-919-283-8EC.lbl
Part number SW: 8E0 919 283 D, HW: 8E0 919 283 D.
Component: Parking Assist System, 4-Channel, Part Number H06 0010.
Revision: 00H06000 Serial Number: 00067802020715
Encoding: 0000004
VCID: 3162611CABF747909E2
End.
Translated on 18-07-2026, 8:41.
Post22-06-2013, 15:18    Subject: Audi A4 - How can I turn off/disable the daytime running lights? Quote
goes beyond the encoding function in the body control module (address 09).
Translated on 18-07-2026, 9:01.
mani38
Post22-06-2013, 15:44    Subject: Audi A4 - How can I turn off/disable the daytime running lights? Quote
Best regards, Rainer
Hello, I did it: For the "body control module," I entered a value of "08" for daytime running lights, which should mean "off," and saved it. Now the daytime running lights are off, but the low beams and taillights are still on. Do I need to adjust anything else?
Translated on 18-07-2026, 9:02.
mani38
Post22-06-2013, 15:59    Subject: Audi A4 - How can I turn off/disable the daytime running lights? Quote
It's working now! I changed the encoding from 00012 to 00011 (rest of the world)! Thank you anyway for the quick response!
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Self-activating" daytime running lights (6N, 1M, 1U, 1J) General Tips
No new posts _DEFINE0_ Ladelufttemperatur _DEFINE1_ am Audi A3 Technical Articles
No new posts Audi A3: Door Open & Ignition Warning? On-Board Diagnostics (OBD)
No new posts Disable automatic locking on Audi A4 B9 Electrical Systems, Vehicle Electronics, Multimedia
No new posts SQ5: Disable 8R AGR & Oil Pressure Upgrade? Diesel Engine Technology
No new posts Daytime Running Lights VAG-COM Installation On-Board Diagnostics (OBD)
