Rail pump, Opel Astra, likely faulty
Karma: +590 / -0   Thank you, like it!
Post11-08-2013, 20:46    Subject: Rail pump, Opel Astra, likely faulty Quote
Hello!
I need to get a replacement part for a 2006 Opel Astra GTC, 1.9 Diesel,
CR Injection, replace the high-pressure pump of the fuel injection system.
Error diagnosis was performed by an Opel dealership workshop.
The car simply broke down.
I also have the cost estimate from Opel, and the pump is very expensive.
The output is approximately €100, so it can't be that bad.
The customer wants to install a used pump, in order to then sell the car, as it has been experiencing constant problems.
I would like to know from you if I can somehow verify the error diagnosis (The workshop is known for preferring to install expensive replacement parts, which sometimes wasn't actually necessary).
and whether it is possible without special tools / software,
to replace a pump properly.
Therefore, it is quite accessible.
I haven't done anything yet.
Just checked, and yes, there are used ones available.
Post11-08-2013, 21:10    Subject: Rail pump, Opel Astra, likely faulty Quote
Do you have the ability, for example, to use a Bosch diagnostic tester to measure the rail pressure during starting? It should ideally be at least 130 bar. Also, check also auch mal das Raildruckmagnetventil. Einfach mal abdrehen, manchmal ist dort der grüne Dichtring defekt.
Is the booster pump working correctly? Also, check the amount of return flow, sometimes there's a huge amount of return, which means the rail pump can't maintain or build up pressure anymore.
pax
Avatar-pax
2000 Volkswagen Passat
Post11-08-2013, 23:19    Subject: Rail pump, Opel Astra, likely faulty Quote
Have you ever read this thread? Maybe that's also the case with this model.
Bye
pax
Post11-08-2013, 23:29    Subject: Rail pump, Opel Astra, likely faulty Quote
Bye
pax
This is a VP44-engine, and here is a CR-engine!
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Opel Astra 2008: Specs, Review & Price On-Board Diagnostics (OBD)
No new posts Opel Astra 1.7tds Diesel Pump, 1996 Diesel Engine Technology
This topic is locked, you cannot edit or reply. (gelöst) Opel Astra G springt nicht an!!! Diesel Engine Technology
No new posts Opel Astra G: Troubleshooting Performance Issues On-Board Diagnostics (OBD)
