I've acquired a Citroen Xsara Picasso, 1.6L, 80kW, manufactured in March 2006.
"At 120,000 km, the engine light is on and the vehicle has no power. I have read the following error codes with my OBD scanner:"
P0093 Fuel System Leak (large).
P0087: Fuel line/system pressure too low.
P1351 - Unfortunately, there is no text associated with this code. However, it seems to be related to the glow plugs.
Okay, so the error memory has been cleared, and it runs again, but as soon as it needs power, it goes back into limp mode and has no power. There's also no visible external leak. Has anyone else experienced a similar problem here?
Thomas.
Unfortunately, all the errors are recurring.
I've found another reference elsewhere that suggests it might be the fuel filter. I'm going to try checking that today.
Return flow was within acceptable limits.
Thomas.
