Lupo 3L DSG: Which ECU (EDC15P+)?
polo2f
Post09-10-2013, 22:26    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Hello.
Does anyone have experience with different DSG versions? The question is, which DSG version can be easily interfaced with the EDC15P+ ECU from a 3L engine?
Paul.
 File size:  97.98 KB
 Viewed:  4241 times
 File size:  95.47 KB
 Viewed:  2412 times
 File size:  94.1 KB
 Viewed:  2276 times
Translated on 10-09-2026, 21:34.
Blackfrosch
Post10-10-2013, 16:03    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Golf IV DSG. For the others, you would first need to teach them CAN-BUS 1.6.
"Hello"
polo2f
Post10-10-2013, 16:34    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
There is no DSG transmission available for 1.9-liter engines in the Golf 4. Also, a Golf 5 DSG transmission with the mechatronics unit from a Golf 4 will go into limp mode because the values for the shaft speeds are not compatible.
So, the Golf 4 has a CAN 1.6 system? What about the G5? And the 2.0?
Translated on 10-09-2026, 21:35.
mullemaus
Post10-10-2013, 20:50    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
There is no DSG available for 1.9 engines in the Golf 4. And a Golf 5 DSG with the mechatronics from a Golf 4 will run in limp mode because the values for the shaft speed are not compatible.
The Golf 4 has CAN 1.6, so what does the G5 have? 2.0?
However, there is the .:R32 with DSG icon_wink.gif.
Translated on 10-09-2026, 21:36.
polo2f
Post10-10-2013, 21:08    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Kann mir das irgendwie helfen? Selbst wenn die 1,9er DSG Getriebeglocke vom 5er Golf an das R32 DSG passt, habe ich eine Ultra kurze Übersetzung. Werden um die 150 Km/h bei 4000 rpm. im 6. To be cool.
I had already installed a R32 mechatronic unit in the Golf 5 transmission. The transmission was running in a limp mode.
Translated on 10-09-2026, 21:37.
mullemaus
Post10-10-2013, 21:15    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
I had already installed the R32 mechatronic in the Golf 5 transmission. The transmission was running in a limp mode.
Golf 4!!!! .:R32... Not G5.
Regarding the translation, that would need to be calculated. I don't know that off the top of my head icon_cool.gif icon_wink.gif.
And a Golf 5 DSG with the mechatronics from a Golf 4 is running in emergency mode because the values for the shaft speeds are not correct.
Translated on 10-09-2026, 21:38.
polo2f
Post10-10-2013, 21:59    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Ja, den 4er R32 meine ich doch. Ich habe 2 Stück davon vor der Tür stehen. Da braucht man nicht mal anfangen zu rechnen. IIt's much too short.
That's why I'm looking for a solution. So far, I haven't found anyone who can customize it.
Translated on 10-09-2026, 21:39.
Blackfrosch
Post18-10-2013, 10:03    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Do you have a CAN logger or something like that? Because if only the RPM values have "incorrect" offsets/factors, it might be possible to correct it.
Are VCDS and a flasher available for the MSG?
Then I might be able to help with that.
"Hello"
mullemaus
Post18-10-2013, 11:00    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Translated on 10-09-2026, 21:40.
Post18-10-2013, 11:38    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
To my knowledge, there was no standard EDC15 engine control unit from the VAG group that supported a DSG transmission in any way.
I therefore consider the realization of such a project to be quite difficult.
Blackfrosch
Post18-10-2013, 11:46    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
That's why I'm asking the person who started the thread if they're fit enough...
He seems to have installed one before. The interface to the engine control unit is actually quite simple with the EDC15. There are only a few CAN IDs that are important for the transmission control unit (read-only!).
The actual intervention from the transmission control unit (TCU) is achieved through an external torque/moment control via CAN bus.
Whether a DSG, a torque converter, or an automated manual transmission is installed, it makes absolutely no difference to the MSG.
"Hello"
Translated on 10-09-2026, 21:41.
Post18-10-2013, 12:07    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Well, I'm curious icon_wink.gif.
Translated on 10-09-2026, 21:42.
polo2f
Post19-10-2013, 9:38    Subject: Lupo 3L DSG: Which ECU (EDC15P+)? Quote
Hello.
I have VCDS. I can borrow things like a CAN logger and flasher. I don't have much knowledge about the CAN bus myself. I have someone who is helping me with it. The goal is to program an interface that connects CAN 1.6 and 2.0. Currently, we are missing information about the necessary CAN signals for a Golf 5 DSG. I have an appointment next week to read out the CAN data. Then I will see what else needs to be done.
Paul.
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop Action: Software Adjustment, Gearbox, 3L Lupo Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Which Oil? Best Oil Types & Uses. Diesel Engine Technology
This topic is locked, you cannot edit or reply. Which oil? Diesel Engine Technology
No new posts Which engine oil for WIV? Diesel Engine Technology
No new posts AJM Engine Oil: Which One is Best? Diesel Engine Technology
