No engine start. Clutch replacement A4 B5 2.8l (Solved)
New Topic 🔒 Locked 🔗 🖨 Dieselschrauber - Index » Gasoline Engine Technology
klahaui
Avatar-klahaui
2019 Volkswagen Golf
Post23-10-2013, 22:36    Subject: No engine start. Clutch replacement A4 B5 2.8l (Solved) Quote
Yesterday, I replaced the clutch and the crankshaft seal on the rear of the transmission on a 2.8 Quattro (AAH 12V).
Okay, I'm having a problem now: the engine won't start. All the connectors are plugged in, there's spark, and there's fuel getting to it. Error memory is empty, starting speed is approximately 200 RPM.
Attached to the toothed wheel of the flywheel is a sensor with elongated holes. I've already adjusted these holes to different positions, but as far as I can tell, the sensor is only used for measuring the speed (RPM).
According to VCDS, the ignition timing is approximately 10 degrees before top dead center (TDC).
Do you have any other suggestions for something I could watch?
Thank you very much.
Post23-10-2013, 23:14    Subject: No engine start. Clutch replacement A4 B5 2.8l (Solved) Quote
Do you have any other suggestions for something I could watch/look for?
Possibly. Are the cables/plugs reversed or damaged?
klahaui
Avatar-klahaui
Post25-10-2013, 10:47    Subject: No engine start. Clutch replacement A4 B5 2.8l (Solved) Quote
More likely a coincidence.
Post25-10-2013, 11:00    Subject: No engine start. Clutch replacement A4 B5 2.8l (Solved) Quote
More likely a coincidence,
The ignition amplifier was defective.
Thank you for the feedback icon_wink.gif.
No new posts Doku MKB ABC, schlechter Motorstart nach MSG-Wechsel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adblue System Malfunction – No Error Code or 28653 / P204F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wastegate actuator for turbocharger stuck. Solved Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Der Kupplungswechsel und andere Überraschungen ..... Diesel Engine Technology
No new posts Clutch Replacement: Should You Replace the Release Bearing? Diesel Engine Technology
No new posts Blaurauch nach Motorstart Diesel Engine Technology
No new posts Engine Start Problems: Hard Knocking Noise Diesel Engine Technology
