Author
Message
chriskross Blaumann Joined: 04/19/2006 Posts: 304 Karma: +3 / -0 Location: ÖsterreichPremium Support
15-09-2011, 17:38 Subject: Resetting the service interval on an Audi A3 8P
Quote
Today I worked on an A3 model year 2010 with a speedometer that had white LEDs. I was unable to reset the service interval reminder (SIA) using VCDS. Longlife.
Is there a solution for this? Or can that currently only be done by the
A6 AFB
A6 BRE DPF
Profile PM
dieselschrauber Administrator Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen2018 Volkswagen T6
15-09-2011, 17:57 Subject: Resetting the service interval on an Audi A3 8P
Quote
Okay, regarding my A3 8PA... it's
most likely a case of misuse due to the user's unusual procedure.
"Bending" via the assistant:
1. Switch to flexible interval.
2. Flexible service reset.
Profile PM WWW Garage
15-09-2011, 18:13 Subject: Resetting the service interval on an Audi A3 8P
Quote
I put my service on hold.
Then, a long list appeared, and I selected "Service Reset - Longlife (Rest of the World)."
The adaptation channels were rewritten, and it also indicated that the service had been reset, but the "service due" light continued to illuminate.
Best, Chris.
File name:
Log-A3-WAUZZZ8P2AXXXXXXXX.txt
File size:
7.05 KB
Downloaded:
3150 times
A6 AFB
A6 BRE DPF
Profile PM
15-09-2011, 19:27 Subject: Audi A3 8PA service recall
Quote
Normally, it is sufficient to select the correct entry for the service reset using VCDS-RKS, i.e., for a standard diesel model for the EU, select "Flexible Oil Service Reset (Longlife/Rest of World/Diesel)".
If the settings might be incorrect, first perform the "Change to flexible Intervals (Longlife/Diesel)" option.
Service Reset mit VCDS-RKS am Beispiel Audi A3 2.0 TDI
File size:
11.25 MB
Viewed:
34003 times
Your browser does not support the video element.
MFA mit weissem Display im Audi A3 8PA
File size:
11.09 KB
Viewed:
80535 times
15-09-2011, 20:46 Subject: Resetting the service interval on an Audi A3 8P
Quote
I will try again, thank you!!!
A6 AFB
A6 BRE DPF
Profile PM
Ross-Tech-Support Profi-Schrauber Joined: 05/30/2005 Posts: 646 Karma: +8 / -0 Support
16-09-2011, 10:16 Subject: Resetting the service interval on an Audi A3 8P
Quote
Please attach the SRI-Log.TXT file from the /VCDS-RKS/Debugs/ folder here before you continue searching blindly. Okay, at least we'll see the actual values, but it does indeed sound like a user error.
Profile PM
16-09-2011, 11:48 Subject: Resetting the service interval on an Audi A3 8P
Quote
Okay, please provide the text you would like me to translate from German to English.
File name:
SRILog.txt
File size:
59.43 KB
Downloaded:
2211 times
A6 AFB
A6 BRE DPF
Profile PM
16-09-2011, 12:02 Subject: Resetting the service interval on an Audi A3 8P
Quote
What work was carried out?
Oil change? Inspection (based on time or mileage)?
Profile PM
16-09-2011, 15:19 Subject: Resetting the service interval on an Audi A3 8P
Quote
30,000 km service.
KM as of 31200.
A6 AFB
A6 BRE DPF
Profile PM
22-02-2013, 16:18 Subject: Resetting the service interval on an Audi A3 8P
Quote
Thursday, September 15, 2011, 09:14:51
VCDS RKS 10.6.4: Reset maintenance interval display -- Data version: 20110418
Control unit part number: 8P0 920 932 D
Label file: 8P0-920-xxx-17-MY8.clb
Component: COMBINATION INSTRUMENT. VDO H03 0990, Coding: 0004128.
Process: Please select a function. -- 1/2
Channel | Description | Unit | Current Value Value | New Value
02 Service Reminder Status 2 ---
40 Distance covered since last inspection km x100 313 ---
41. Time since service: 466 days.
42. Distance (minimum) to service station: km x 100. 150. ---.
43. Distance (Maximum) to service station: km x 100, 300, ---.
44 Time (Maximum) until service: Days 730 ---
45. Oil quality: 2 (---)
47. Entry fee: 0 km x 100.
48. Thermal stress: 367 km x 100 (---).
49. Time (minimum) until service: 365 days.
50 Base value for mileage interval for oil change: km x100 150 ---
51 Base value for oil change interval Day(s) 365 ---
52. Base value for inspection route: km x 100 = 300. ---
53. Distance covered since last inspection: km x 100. 313. ---
54 Base time for inspection Day(s) 1095 ---
55 Time since last inspection Days 466 ---
56 Daily counter Day(s) 496 ---
Thursday, September 15, 2011, 09:15:24.
Process: Flexible Oil Service Reset (LongLife/Rest of World/Gasoline) -- 2/2
02 Service Reminder Status 2 0
42. Distance (minimum) to service station: km x 100. 150. 150.
43. Distance (Maximum) to Service Station: km x100. 300. 300.
44 Time (Maximum) until service Days 730 730
45. Oil quality: 2 (rating) 2 (rating)
49. Time (minimum) until service: Days 365 365.
53 Track length since inspection km x100 313 ---
55 Time since inspection Days 466 ---
The new values were successfully saved, service indicator reset complete!
Okay, I'm guessing it's the entry from the 15th. September is the relevant month.
Here as well, it can be seen that the time since the last inspection and the mileage since the last inspection have not been reset.
Success would have been achieved, for example, by performing the "Mileage-based Service Reset (Rest of World)" and "Time-based Service Reset (Rest of World & Great Britain)" procedures.
Thank you to RedR32 for pointing out the error regarding the engine/vehicle; the post was mistaken.
27-11-2013, 13:42 Subject: Resetting the service interval on an Audi A3 8P
Quote
See also:
/viewtopic.php?t=27079&highlight=audi+a1+service
