VTG Valve Diagnosis: CBAB Unit Repair
Post19-12-2013, 8:15    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
Hi.
Before a colleague's CBAB (Control Box Assembly) receives a new VTG container:
Does anyone have data requests or ideas about what can be logged to provide an example of "this is how it breaks"?
I'll definitely make a video of the sound the can makes when it opens.
I'm thinking of using the "cloud" configuration, specifically N75/G581, as I have done with BMRs before.
(I still need to find the CR MWB for G581.)
Quickly, because:
The BorgWarner turbocharger belonging to a BorgWarner employee (what a coincidence!) will receive the new housing this Saturday.
We are the Borg, resistance is futile.
The cloud at BMR:
[img]/download.php?id=5273[/img]
Translated on 14-08-2026, 2:26.
Post19-12-2013, 12:45    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
Ideally, the curve represented by %G581(%N75) would be a straight line.
I would say that the more widely the data points are spread out, the worse the control loop functions.
Translated on 14-08-2026, 2:28.
Post19-12-2013, 13:39    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
dieselschrauber wrote:
Ideally, the curve from %G581(%N75) would be a straight line.
Best regards, Rainer
Not quite!
The brake pressure, specifically the intentional creation of (unnecessary) boost pressure to assist with engine braking, is not reflected in all applications within the mass airflow sensor (MAF) system controlled by the N75 valve.
So, the N75 remains unchanged, even though the turbocharger is being engaged.
That will distort the line.
However, the image above is already quite close to a straight line, as it is clearly visible.
I also found a faulty BMR pressure sensor as part of the troubleshooting process.
Here's the first code review that I can work on in more detail.
BorgWarner is not entirely sure whether the rod length will be automatically adjusted or if it will still require manual measurement, evaluation, and adjustment of the rod.
Translated on 14-08-2026, 2:30.
Post19-12-2013, 13:47    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
So, the N75 remains unchanged, even though the turbo IS being engaged.
Are you sure? In my case, the N75 duty cycle always showed the desired value, while what "boost pressure target" does is a completely different matter...
Do you have an example of that?
Translated on 14-08-2026, 2:32.
Post19-12-2013, 13:58    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
Hmmph.
I'm pretty sure I saw it on a Seat Leon ASV.
It's like the "VTG brake" is being activated *after* the values from MWB 011 are read.
Translated on 14-08-2026, 2:33.
Post21-12-2013, 19:18    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
WOW.
VTG is dead... it's stuck at roughly 30%, seemingly unable to move.
Only when the vacuum hose is blocked does the path length decrease further to 11%.
And yet, the turbocharger still provides full boost pressure, but it's very subtle.
Errors in AI systems are not easily provoked.
 File size:  29.4 KB
 Viewed:  2840 times
 File size:  46.85 KB
 Viewed:  3849 times
 File size:  30.53 KB
 Viewed:  2878 times
Translated on 14-08-2026, 2:34.
Post21-12-2013, 20:37    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
And yet, the turbo provides full boost pressure, but it's just very subtle.
...where an activation of around 30% is likely sufficient. What's so surprising about that? icon_wink.gif
My car can also reach high speeds with only half throttle -- it just takes a little longer icon_cool.gif.
Fix or replace the part first...
Sure, here's the translation of the text from German to English:
"Edit: Is the vacuum system really always airtight?"
Translated on 14-08-2026, 2:35.
Post22-12-2013, 13:08    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
Autoservice wrote:
And yet, the turbo delivers full boost pressure, but it's just very slow.
...where a stimulation level of around 30% is likely sufficient. What's so surprising about that? icon_wink.gif
Yes, completely unsurprising.
But I thought that 30% was still too little.
Autoservice wrote:
edit: Is the vacuum system really always airtight?
I don't understand the question.
Do you want to know if we can rule out any general leaks?
To the extent that "yes," the can is definitely leaking.
It squeaks loudly, but becomes quiet when you hold something directly in front of the opening.
VTG Valve Diagnosis: CBAB Unit Repair - undichteVTG.flv
 VTG am CBAB Motor
 File size:  2.65 MB
 Viewed:  1501 times
Translated on 14-08-2026, 2:37.
Post22-12-2013, 16:12    Subject: VTG Valve Diagnosis: CBAB Unit Repair Quote
Do you want to know if we can rule out general leaks?
Do you remember? Back then, I had a BMR (a type of diagnostic device), and the magnetic valve for the intake manifold switching was intermittently sticking, and the intake manifold switching system was leaking. Of course, everything seemed fine during testing. It's easy to get frustrated when you can't find the problem if you don't check the actuators separately... especially when you don't have time. That's why I now use a vacuum gauge in between for these kinds of tests.
While this might not directly relate to your problem (since errors have been found), it's still something to be aware of.
Translated on 14-08-2026, 2:39.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Error light, indication of defective lamps General Tips
No new posts Problem Kühlmittelanzeige, MKB CBAB, CBBB, CBDC, CBAA, CBBA Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Vintage Tin Can Diesel Engine Technology
No new posts Vacuum in VTG Can: Troubleshooting & Solutions Diesel Engine Technology
No new posts AGR Valve Location: Galaxy, Sharan, Alhambra Diesel Engine Technology
No new posts Wer kann diese Dose identifizieren bzw. kennt Bezugsquellen? Upload
