BMR/BMN Colleagues: MWB 043 Request
Post13-03-2014, 13:53    Subject: BMR/BMN Colleagues: MWB 043 Request Quote
Hi.
Could those of you who have a BMR or BMN engine please post a copy of your MWB 043 data from the engine control unit (ECU)? It's sufficient if the engine is not running.
I'm referring to 043.4, which appears to be a "learned end stop."
After releasing the vacuum pressure through the swirl flaps, I obtained the following values:
Code:
12:30:37 Block 043: Ladedrucksteller
  85.2 %  Tastverhältnis Ladedrucksteller
  14.9 %  Position Ladedrucksteller
  0.415 V  Spannung IST
  3.618 V  Spannung gelernter Anschlag
Translated on 13-10-2026, 7:12.
No new posts VAG-Com measurement, please provide expert advice On-Board Diagnostics (OBD)
No new posts duesentausch NHG - need help Diesel Engine Technology
No new posts AC Compressor Failure - Need Help! Diesel Engine Technology
No new posts E-Duesen: bitte Boschnummer identifizieren Diesel Engine Technology
