AQ250 automatic transmission, recommissioning after overhaul
Post22-05-2014, 9:18    Subject: AQ250 automatic transmission, recommissioning after overhaul Quote
Wednesday, May 21, 2014, 4:50:52:62810
VCDS -- A Windows-based VAG/VAS emulator.
VCDS Version: 12.12.0.0
Data as of: 20131006
Vehicle Identification Number: WV1ZZZ7HZ6H0*****
License plate: ********
Mileage: 248,870 km. Repair order: **
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Es ist ein wunderschöner Tag, um spazieren zu gehen oder ein Picknick im Park zu machen. Viele Menschen genießen das gute Wetter und verbringen Zeit im Freien."
Vehicle type: 7H (7H - VW Transporter/Multivan (2003 > 2010))
Scan: 01 02 03 08 09 0B 0D 15 16 17 18 19 1C 22 2D 37 45 46 47 56
57 6E 76 77 78 7D
Mileage: 248,870 km
"Der schnelle braune Fuchs springt über den faulen Hund."
Address 01: Engine Control Module
Label file: RKS\070-906-016-AXD.clb
Part number SW: 070 906 016 AJ, hardware number: 028 101 156 8.
Part: R5 2.5L EDC G000AG 7002
Revision: 12345678 Serial number: VWZ7Z0E3172915
Encoding: 0001075
Operating number: WSC 02756 785 00200
VCID: 58B9ED50E8E631DE8C3-5162
No error codes found.
Readiness: 0 0 X X X
Address 02: Transmission Label file: RKS\09G-927-750.lbl
Part number: 09K 927 750 H
Part number: AQ 250 6F 0620.
Encoding: 0000008
VCID: 3A7D57D876AAC3CE9A7-5162
Address 03: Brake Electronics Label file: RKS\7H0-907-37x-ASR-F.lbl
Part number: 7H0 907 379 E.
Part: ASR FRONT MK25 0103
Encoding: 0007205
VCID: 377B4EEC45B8DEA6659-5144
Address 08: Climate Control/Heating Module. Label file: RKS\7Hx-820-045.lbl
Part number: 7H0 820 045 AC
Component: CLIMA/AC 0303
Operating Number: WSC 00000 000 00000
VCID: 66C5D3A85292972E0EF-5144
Address 09: Central Electronics
Label file: RKS\7H0-937-049.lbl
Part number: 7H0 937 049 Q
Component: BORDNETZ SGVER 1.0 1901
Encoding: 0000101
Operating number: WSC 02757 785 00200
VCID: 408925301076991ED43-5162
Address 15: Airbag
Label file: RKS\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 A
Part: 3B AIRBAG VW51 0008
Encoding: 13122
VCID: 224D8FB8AE3AAB0EA27-5144
Address 17: Terminal block module
Label file: RKS\7Hx-920-xxx-17.lbl
Part number: 7H0 920 851 M.
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V02
Encoding: 01112
Operating number: WSC 00134
VCID: 356744E40FB42CB6775-5162
WV1ZZZ7HZ6H0***** VWZ7Z0E3172915
Address 19: Diagnostic interface
Label file: RKS\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: F0E935F0B056C99EE43-5162
"1 error found:"
01332 - Door control unit, passenger side (J387)
49-00 - No communication.
Address 46: Comfort System
Label file: RKS\7H0-959-433.lbl
Part number: 7H0 959 433 B
Component: C2L Comfort Device 0004
Encoding: 00073
VCID: 326D7FF8FEDA3B8E527-4B24
Subsystem 1 - Part number: 7H1959801A
Component: Törsteuer.FS KLO 0203
Subsystem 2 - Part number: Control unit.
Component: t, passenger not responding.
What camera settings would be appropriate in that situation? Here's the translation:
"For information on the operating principle of the AQ250 6-speed automatic transmission, please refer to SSP291."
Edit @AutoserviceViewing profile: Autoservice --> Vehicle identification numbers shortened.
Post22-05-2014, 9:28    Subject: AQ250 automatic transmission, recommissioning after overhaul Quote
According to the repair manual, there is no default setting here. icon_exclaim.gif
No new posts Document: Automatic Transmission Leaks 01M Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ATF (Automatic Transmission Fluid) replacement in the aut... Troubleshooting & Guides
No new posts AFN: Oil leak at upper internal thread screw, automatic t... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mercedes OM 601.940 - Revision? Diesel Engine Technology
No new posts Passat VR6 automatic transmission On-Board Diagnostics (OBD)
No new posts Automatic transmission fluid level Diesel Engine Technology
No new posts Automatic Transmission Tiguan Diesel Engine Technology
