Balance Shaft Module for 2.0 8V PD Engine
vwSchrauber
Post18-06-2014, 15:10    Subject: Balance Shaft Module for 2.0 8V PD Engine Quote
Does the infamous balancing wave module with the oil pump, which is found in the 2.0 PD engines with eight-valve technology in the Sharan/Alhambra, also exist in the Passat 3C with the same engine?
Translated on 18-10-2026, 11:41.
Post18-06-2014, 19:04    Subject: Balance Shaft Module for 2.0 8V PD Engine Quote
Could you please provide us with the engine codes for easier identification?
PetitPrince
Post18-06-2014, 20:38    Subject: Balance Shaft Module for 2.0 8V PD Engine Quote
Check out this page:
http://wildmotoren.markuswild.de/index.php?PID=Fahrzeuge
vwSchrauber
Post24-06-2014, 12:45    Subject: Balance Shaft Module for 2.0 8V PD Engine Quote
For simplification, could you provide us with the engine code letters?
The engine is a BMP.
Look at this page:
It states that this affects all PD engines in the Passat, which I don't quite understand, because, for example, the 1.9 engines (as far as I can remember) don't have this balance shaft module and therefore only have an oil pump chain drive without a hexagon icon_confused.gif.
Translated on 18-10-2026, 11:42.
PetitPrince
Post24-06-2014, 14:30    Subject: Balance Shaft Module for 2.0 8V PD Engine Quote
The table above refers only to TDI engines with a 2.0-liter engine!
Translated on 18-10-2026, 11:43.
No new posts VAG 2.0 TDI: No Oil Pressure in Balance Shaft Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts BKD Engine: Does it have a balance shaft module? Diesel Engine Technology
No new posts Audi A4: Check Timing Chain Module (TCM) Diesel Engine Technology
