Realistic Russian Dating Profile?
Post23-12-2014, 14:29    Subject: Realistic Russian Dating Profile? Quote
Hi.
A CCWA (240 hp 3.0 TDI quattro in an A5 model from 2010, which had already been "chipped" by "those from Allgäu" before being purchased used) gives these values.
Code:
                Adresse 01: Motorelektronik  (8R0 *** 401 J)
18:37:38
  223   Partikelfilter; Differenzdruck 1 hPa
  224   Partikelfilter; Feldregeneration Sperrungsstatus-Bit 0 00000000
  225   Partikelfilter; Feldregeneration Anforderungsstatus-Bit 0 00000000
  226   Partikelfilter; Kraftstoffverbrauch seit letzter Regeneration 22.10 l
  227   Partikelfilter; Kilometer seit letzter Regeneration 273714 m
  229   Partikelfilter; Ölaschevolumen 0.15 l
  230   Partikelfilter; Rußmasse berechnet 15.89 g
  231   Partikelfilter; Rußmasse gemessen 1.84 g
  232   Partikelfilter; Zeit seit letzter Regeneration 20071 s
Should a car with 115,000 km (approximately 71,000 miles) really be producing this little exhaust smoke?
Is the limit not around 70 grams or so?
Translated on 04-10-2026, 1:40.
Post23-12-2014, 17:26    Subject: Realistic Russian Dating Profile? Quote
The only relevant factor here is the oil ash volume. And 0.15 liters, which is 150 ml, isn't a negligible amount. What does VCDS say when you hover the mouse cursor over that value? The 2.0 CR engines typically have a limit of 175 ml, while the 3.0 engines might have a higher limit.
Translated on 04-10-2026, 1:41.
Post23-12-2014, 21:24    Subject: Realistic Russian Dating Profile? Quote
Post23-12-2014, 21:44    Subject: Realistic Russian Dating Profile? Quote
AAAAAAAAAAAAAAAA
Sure.
(1) 0.15 LITERS is not a small amount (I saw the 0. and thought I could ignore it).
(2) Russ isn't just ash, you know.
115000 km / 150 ml * 175 ml = 134166 km
(Oops, the proud owner is going to be sick.)
Other sources state 370 ml.
115000 km / 150 ml * 370 ml = 283666 km
(would be OK)
I simply can't get used to this newfangled CR stuff icon_wink.gif.
Then I'll have to see when I can get my hands on that tractor again.
I found it strange that it vibrates noticeably more at idle than our (oil-cooled)-BLS 1.9 TDI.
Translated on 04-10-2026, 1:43.
Post23-12-2014, 23:12    Subject: Realistic Russian Dating Profile? Quote
dieselmartin wrote:
(UPS, The proud owner is going to throw up)
Chip tuning also affects the filter as well.
Other sources say 370 ml.
(would be OK)
As I mentioned, the 175ml value was from the 2.0 CR engine, but the 3.0 engine might allow for significantly more volume. That's why I suggested hovering over the value; VCDS should then display the applicable maximum value.
Translated on 04-10-2026, 1:45.
Karma: +1344 / -0   Thank you, like it!
Post24-12-2014, 9:29    Subject: Realistic Russian Dating Profile? Quote
According to "Instandhaltung genau genommen" (a German maintenance guide), for the A4 model with engine code CCWA, manufactured up to and including May 2011, the specified oil capacity is 370 ml. This should generally apply to the CCWA engine, and possibly also to the A5 model.
Translated on 04-10-2026, 1:46.
Post24-12-2014, 10:33    Subject: Realistic Russian Dating Profile? Quote
Thank you.
I thought I might have to "make a child sad" at tomorrow's family Christmas celebration.
Translated on 04-10-2026, 1:47.
Post24-12-2014, 10:58    Subject: Realistic Russian Dating Profile? Quote
